Wheels Polished Lip -- Lacquer ?
Jellybean
The lips on my LMs are just polished with no lacquer, and when brake dust had started to stick the surface, a clay and polish brought them back to new. I guess with lacquer that if anything eats into it, you may have to strip it back to rectify it. Plus, after a Google, it seems lacquer chips off polished metal quite easily.
Edited by Josh (see edit history)
Laquered lips will take a bit of an fully mirror polished lip's shine away, will last longer BUT when laquer is damaged in a way you'll need to remove the laquer to get them lips re-polished. Without laquer the shine will be more intens so will look better, (but without an protection oxidation (white rust on aluminum) will start right after you finished an re-polish cycle.
thanks for the info , going to GTechniq C5 Wheel Armour them as suggested by Jimo, then use peeks polish and maybe Autosol if I need to remove oxidation or rust
Just to say I,ve always taken the lacquer off my wheels. In fact, hopefully this weekend I,m doing it again. The lips are not in a good shape , so I,ll be sanding off the lacquer , then buffing all the way to perfection.
I,ve got everything ready for the transformation , 3000, 2000,1500,1200,800,400 grit . Got various cutting creams , polishes , and finishing wax. Think this is gonna be a mega job !!!!! If going by how long it took me last time , I,m giving it 2 days per rim ( they are very bad ) . I,ll take some pics if I remember .
Edited by lewysdanny (see edit history)
