Gretie22 Posted February 13, 2014 Share Posted February 13, 2014 Accelerated off the traffic lights the other day and the mil light lit up briefly, car acted normally. I've just done a diagnostics check and there's no stored codes. So any ideas what could of caused this? Quote Link to comment Share on other sites More sharing options...
Thorin Posted February 13, 2014 Share Posted February 13, 2014 Does it happen when braking sharply too? Could be brake fluid slightly low when sloshing around. Quote Link to comment Share on other sites More sharing options...
Gretie22 Posted February 13, 2014 Author Share Posted February 13, 2014 Only happened the once. I'll go out and check the brake fluid now. Thanks Quote Link to comment Share on other sites More sharing options...
Thorin Posted February 13, 2014 Share Posted February 13, 2014 Low fluid can trigger the light even if it's only very slightly below the level. Hopefully it's just that. Quote Link to comment Share on other sites More sharing options...
mattdavies Posted February 13, 2014 Share Posted February 13, 2014 My brake fluid has to be between the min and max or above to stop the light coming on Quote Link to comment Share on other sites More sharing options...
Gretie22 Posted February 13, 2014 Author Share Posted February 13, 2014 Just checked it, its on max! Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted February 13, 2014 Share Posted February 13, 2014 Maybe a brief misfire or traction warning? Quote Link to comment Share on other sites More sharing options...
Josh Posted February 13, 2014 Share Posted February 13, 2014 Could have hit fuel cut briefly if you've not got a FCD fitted Quote Link to comment Share on other sites More sharing options...
Gretie22 Posted February 13, 2014 Author Share Posted February 13, 2014 Slip control light didn't come on. Brake fluid is due a change though looking a little darker than it should :/ Quote Link to comment Share on other sites More sharing options...
Gretie22 Posted February 13, 2014 Author Share Posted February 13, 2014 No FCD fitted so could be that. Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted February 13, 2014 Share Posted February 13, 2014 Did it stutter? Like it had hit the limiter Quote Link to comment Share on other sites More sharing options...
Gretie22 Posted February 13, 2014 Author Share Posted February 13, 2014 Did it stutter? Like it had hit the limiter No nothing out of the ordinary. Quote Link to comment Share on other sites More sharing options...
Josh Posted February 13, 2014 Share Posted February 13, 2014 I hit fuel cut once in 2nd as the second turbo came on going up a hill on a cold day. I let off as soon as lights started coming on and I didn't feel the "jolt" you hear about, but maybe I let off in time. Quote Link to comment Share on other sites More sharing options...
Gretie22 Posted February 13, 2014 Author Share Posted February 13, 2014 I hit fuel cut once in 2nd as the second turbo came on going up a hill on a cold day. I let off as soon as lights started coming on and I didn't feel the "jolt" you hear about, but maybe I let off in time. Didn't let off, couldn't let the bmw past It only flashed briefly so sounds as if it could be a brake fluid thing, if the weather is good at the weekend I'll get my partner to change the brake fluid then take it out for a blast. Quote Link to comment Share on other sites More sharing options...
Digsy Posted February 13, 2014 Share Posted February 13, 2014 (edited) Check that when you turn the ignition key to the second position but BEFORE you crank that all the warning lights come on just in case you are getting a secondary warning light but the bulb is blown. IIRC it's not the MIL that illuminates when you have low brake fluid, anyway. It's the master warning triangle and the brake warning light. MIL usually indicates a problem with the engine, transmission or ECU but that should store a fault code. Edited February 13, 2014 by Digsy (see edit history) Quote Link to comment Share on other sites More sharing options...
