scott87 Posted February 12, 2014 Share Posted February 12, 2014 Can someone tell me if the power steering, alternator and water pump pulleys are the same on the na as the turbo. Link to comment Share on other sites More sharing options...
Guest Budz86 Posted February 12, 2014 Share Posted February 12, 2014 Yes as far as I can remember Link to comment Share on other sites More sharing options...
benji56 Posted February 12, 2014 Share Posted February 12, 2014 Yep they sure are dude! Link to comment Share on other sites More sharing options...
scott87 Posted February 12, 2014 Author Share Posted February 12, 2014 Sweet thanks. Just bagged a set cheap on ebay Link to comment Share on other sites More sharing options...
David P Posted February 12, 2014 Share Posted February 12, 2014 The T.T. alternator pulley is a nodger larger, Shane posted about it and the slightly different length belts. It just so happens that the alternator pulley I have for sale I think is N/A size. Link to comment Share on other sites More sharing options...
scott87 Posted February 12, 2014 Author Share Posted February 12, 2014 The T.T. alternator pulley is a nodger larger, Shane posted about it and the slightly different length belts. It just so happens that the alternator pulley I have for sale I think is N/A size. How much bigger? Can the tensioner not just be loosened off slightly to compensate? If the set isn't suitable i will just apologise to the seller and pull out of the transaction and pay the fees, literally last second buy as it was cheap. Didnt have chance to check first. Link to comment Share on other sites More sharing options...
David P Posted February 12, 2014 Share Posted February 12, 2014 Nothing to lose sleep over. I've been looking for Shanes posting of the exact TT - N/A alternator pulley dimensions and belt length post, but give up. Link to comment Share on other sites More sharing options...
scott87 Posted February 12, 2014 Author Share Posted February 12, 2014 Ok thanks David. So was that a possibly of adjusting the tensioner? Link to comment Share on other sites More sharing options...
David P Posted February 12, 2014 Share Posted February 12, 2014 Here you go; http://www.mkivsupra.net/vbb/showthread.php?299335-Altenator-differences&highlight=N%2FA+alternator+difference Link to comment Share on other sites More sharing options...
scott87 Posted February 12, 2014 Author Share Posted February 12, 2014 Thanks. By the looks of that then I will be absolutely fine. The pulley may rotate slightly slower being large but the diameter Is very small. Also I note that the belts are The same for tt and na. Link to comment Share on other sites More sharing options...
David P Posted February 12, 2014 Share Posted February 12, 2014 The belts are different. Link to comment Share on other sites More sharing options...
scott87 Posted February 13, 2014 Author Share Posted February 13, 2014 It says in that thread the belts are the same for tt and na. Link to comment Share on other sites More sharing options...
David P Posted February 13, 2014 Share Posted February 13, 2014 Which could also account for why some people say the 1932 belt fits fine, and others find it a bit on the tight side for comfort. Here's the comment I lead you to. Link to comment Share on other sites More sharing options...
scott87 Posted February 13, 2014 Author Share Posted February 13, 2014 So it's fine but tight? Link to comment Share on other sites More sharing options...
Fly Posted February 13, 2014 Share Posted February 13, 2014 Good luck getting the alternator bolt off, still trying to do mine - - - Updated - - - Good luck getting the alternator bolt off, still trying to do mine Link to comment Share on other sites More sharing options...
scott87 Posted February 13, 2014 Author Share Posted February 13, 2014 Good luck getting the alternator bolt off, still trying to do mine - - - Updated - - - Good luck getting the alternator bolt off, still trying to do mine On the pulley? Already had it off a few times so hoping its not stuck on! Link to comment Share on other sites More sharing options...
Fly Posted February 13, 2014 Share Posted February 13, 2014 hrmmm come and do mine then!! its solid! Link to comment Share on other sites More sharing options...
David P Posted February 13, 2014 Share Posted February 13, 2014 Use a pneumatic spanner and the job is easy. Link to comment Share on other sites More sharing options...
GMan Posted February 13, 2014 Share Posted February 13, 2014 I put tt alternators on both my NAs becuase Germany only had tt supras. can confirm that there is no issues with the belts whatsoever. Link to comment Share on other sites More sharing options...
David P Posted February 13, 2014 Share Posted February 13, 2014 (edited) I put tt alternators on both my NAs becuase Germany only had tt supras. can confirm that there is no issues with the belts whatsoever. There's the wrong answer he's been waiting for! What's so difficult with simply changing the belt and doing it almost properly? If you're scrimping, I bet you could pick up a used one up for a pint. Or you could save the cost of a new belt and buy a used yet still nice and shiny and pretty N/A size aluminium pulley with a trendy label at 75% off retail price. Edited February 13, 2014 by David P (see edit history) Link to comment Share on other sites More sharing options...
Swampy442 Posted February 13, 2014 Share Posted February 13, 2014 How much bigger? Can the tensioner not just be loosened off slightly to compensate? The tensioner is spring loaded, it self adjusts Link to comment Share on other sites More sharing options...
scott87 Posted February 13, 2014 Author Share Posted February 13, 2014 There's the wrong answer he's been waiting for! What's so difficult with simply changing the belt and doing it almost properly? If you're scrimping, I bet you could pick up a used one up for a pint. Or you could save the cost of a new belt and buy a used yet still nice and shiny and pretty N/A size aluminium pulley with a trendy label at 75% off retail price. Thanks David, i'll grab a second hand belt if i can then, or just not swap the alternator pulley. i bought the entire set for less than 30quid so dont really want to pay another 30odd for one pulley. It was an impulse ebay buy Thanks for your tech help as always! Im sure if i cant grab a cheap used belt a new tt one will be peanuts anyway Link to comment Share on other sites More sharing options...
David P Posted February 13, 2014 Share Posted February 13, 2014 And I thought; my pulley for less than you may pay for a belt sales-patter, was going so well. Link to comment Share on other sites More sharing options...
scott87 Posted February 13, 2014 Author Share Posted February 13, 2014 (edited) And I thought; my pulley for less than you may pay for a belt sales-patter, was going so well. Oh really I was expecting an aux belt to be around 9quid new. If that is the case I'll come back to you, would rather buy metal for 30quid than rubber or nylon whatever it's made from! *edit* 11 quid for a belt. Edited February 13, 2014 by scott87 (see edit history) Link to comment Share on other sites More sharing options...
David P Posted February 13, 2014 Share Posted February 13, 2014 (edited) Gates black around £17 from local Motor Factor. Gates blue around £84 + £14 P&P. Mr T. O.E. black. around £35. Edited February 13, 2014 by David P (see edit history) Link to comment Share on other sites More sharing options...
