JohnK Posted August 25, 2005 Share Posted August 25, 2005 I need to rotate the aluminium part around 90 degrees, Can I just undo the 4 screws arrowed and move it? What does the screw in the center hold? Quote Link to comment Share on other sites More sharing options...
Miguel Posted August 25, 2005 Share Posted August 25, 2005 The centre screw does absolutely nothing ..Its just the 4 around the outside ..Take some of the tension up in a vice when doing though as them springs have a bite. Quote Link to comment Share on other sites More sharing options...
JohnK Posted August 25, 2005 Author Share Posted August 25, 2005 So I can safely do it without fear of ripping the diaphram or anything? Having never had one apart and no diagrams, im a little unsure. Quote Link to comment Share on other sites More sharing options...
Miguel Posted August 25, 2005 Share Posted August 25, 2005 Yup you will be fine. The top Bolt is puerly a block for another port if required. Just as long as you have a wide enough vice to take up some of the tension, otherwise she will fire the top half up the road. It's very very simple inside with not a lot to go wrong or mess up . There's only a spring, a spring cup that sits on the diaphram and the diaphram itself..which is quite sturdy. Nothing difficult ..just go carefull. Quote Link to comment Share on other sites More sharing options...
JohnK Posted August 25, 2005 Author Share Posted August 25, 2005 Thanks Mig, as always your on top of the game. On another note, I could block the current port and use the center one instead? That may save me turning it 90 degrees. Quote Link to comment Share on other sites More sharing options...
Miguel Posted August 25, 2005 Share Posted August 25, 2005 You can Indeed sir. That bolt originaly was for the GT2 series which has ajustable pre loads for the springs. On yours its just blocked off, as they use the same castings( lazyness) across the board. So yep you can indeed use it as a vac/press port. Quote Link to comment Share on other sites More sharing options...
Miguel Posted August 25, 2005 Share Posted August 25, 2005 Just to clarify its the top port you need to rotate and not the bottom, closest to the valve, you need to rotate? Quote Link to comment Share on other sites More sharing options...
JohnK Posted August 25, 2005 Author Share Posted August 25, 2005 Its the port in the aluminium end furthest away from the valve, sits too close to the steering knuckle for my likeing. Quote Link to comment Share on other sites More sharing options...
Miguel Posted August 25, 2005 Share Posted August 25, 2005 Quote Link to comment Share on other sites More sharing options...
