2JZ-GTE VVTi engine swap for N/A manual. Any problems to expect?
msmile
Guest Roger NE
I presume you're getting the turbo engine complete with its Loom AND ECU?
And did the engine come from a Supra? And was it a Manual? (if so, presume you've also got the 6 speed gearbox?)
so GTE to NA ;)
probably a huge loss of power
Hahaha just noticed my mistake, but cant find how to edit the thread name lol :D:D:D
5speed manual Ive got. I will get the loom and ECU and MAF + ignition pack, just cant find info if its really bad if they all come from Aristo or GS300?
Guest Roger NE
The engine needs to come from a Supra or the Sump is at the wrong end . . .
If you also get the Loom from a Supra and it is from a Manual car then it will be fairly straightforward . . .
If it's from another model you will have a lot of wiring to sort out to interface with the various Body connectors
