Oil filter removal
Suprahitz
Hi guys. I've now owned my 1994 J-Spec TT auto for 6 months now.
Had the car first serviced at Whifbitz when I purchased last year but thought time to give it another oil change myself for first time.
It seems the oil filter is located in quite an awkward position.
I found one thread about changing oil on driveway but the photos were removed.
Another site advised about removing the battery to get better access to the filter. Is this true?
I had a lot of trouble removing mine as I could get a finger and thumb onto it but not enough force to turn it. This was trying from above and below.
I finally gave up and hammered a screwdriver through it and it came off easily that way :)
The proper way is to buy a ratchet strap tool (thing lol) specifically for removing oil filters :)
Edited by Josh (see edit history)
Just get your hands down there and give it a twist :) Having said that, I don't have ABS so I guess access is easier for me.
Depends if you have girly arms too. Mine wouldn't fit. Maybe I should have tried using my left arm instead... ;)
I undo the 10mm bolt that supports the piece of loom that runs down that side of the engine and move it back towards the inner wing out of the way then whack a sharp screwdriver through the filter, making sure I have an old towel under it to catch the innevitable oil spill .......I have also made a ratchet strap out of a canvas belt before now but this was fiddly.......You could remove the battery but I don't think you would gain that much room.
I undo the three 10mm bolts on the power steering reservoir and then you can gain a bit more space for your arm/hand and once it's off get the filter back up through the top.
This. Once you remove the three bolts, you can swing the power steering reservoir out of the way. I use one of these: http://www.ebay.co.uk/itm/NEW-12-OIL-FILTER-ADJUSTABLE-WRENCH-REMOVAL-PLIER-TOOL-/231136115928?pt=UK_Hand_Tools_Equipment&hash=item35d0c93cd8 and it's excellent - never failed me yet on numerous vehicles :thumbs:
You'll obviously have to remove the undertray, to allow the remnants of oil to drain out properly :)
