Codes 22 and 78 please help
Guest jambofuz
Guest jambofuz
Hi all have a issue with my supra,
It really struggles to start from cold
Got these codes from it today 22 and 78
would these codes give cold start issues? cheers J
Guest Roger NE
Yes have you done anything to the wiring?
The engine temperature sensor for the ECU is on the Inlet side of the block, near the front . . it's the only one with TWO wires, so check the plug is on properly.
And the Fuel Pump ECU is in the rear of the car, and has several wires coming from the main Engine ECU - have you disturbed any of the wiring at all?
