ecu opinion?
costas1
Whats different to any other standalone? it just has a base map on the ecu to start the car but if you run aftermarket injectors until you configure them they won't start unless the injector pulse is similar.
Also you need to run a AFR sensor to be able to map the fueling.
Even in that video it showed it was running to rich, which he has to manually map the fueling, it won't map itself!
Its no different to running an aem series 2 or any ecu with a base map
