paul21uk Posted February 8, 2014 Share Posted February 8, 2014 right guys i have a 1jz conversion i was recently using the 2jz na alternator which till recently was running fine now its knackered i came across a good 1jz alternator very cheap, my issue is that i have NO CHARGE coming from it, i have power from battery also have igniton charge and permanent 12v charge but none while the engine is running, i know there are a few guys on here that has the 1jz swap also so if they could point me in the right direction as anyone else that would be great i have searched and not managed to find anything thanks Quote Link to comment Share on other sites More sharing options...
Shane Posted February 9, 2014 Share Posted February 9, 2014 Hi Paul, So long as you have the exciter feed to the field coil connector and the feed to the battery you should be able to get it to charge if it's a good alternator. Here is an example of alternator wiring in it's simplest form: http://www.thecj2apage.com/forums/uploads/769/DelcoSI2wiring.jpg And another: https://www.google.co.uk/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&docid=TIafYOGo7ffeuM&tbnid=PfZUZX8Bld2CTM:&ved=0CAUQjRw&url=http%3A%2F%2Fwww.expeditionlandrover.info%2FDelco_Alternators.html&ei=BkT3UqP0Duii0QXr24GAAw&bvm=bv.60983673,d.ZGU&psig=AFQjCNHZkQzY1SAc-UmY5rLMr1fDwMs9qw&ust=1392022846408695 Although these will work fine and are very simple, i would personally always make sure the exciter feed is ignition switched too just to avoid any drain on the battery when not in use. Quote Link to comment Share on other sites More sharing options...
ghostbuster Posted February 11, 2014 Share Posted February 11, 2014 Well worth getting the alt tested. I've just been there and mine was breaking down as load increased due to rectifier probs. I got mine repaired by a specialist here in Devon (cheaper than replacement). Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 11, 2014 Share Posted February 11, 2014 The usual causes of trouble in 2JZ alternators are oil ingress and / or worn out brushes and slip rings. Quote Link to comment Share on other sites More sharing options...
