Paul-90 Posted February 7, 2014 Share Posted February 7, 2014 Right trying to start my supra. Battery is charged, interior light works, headlights work, light around ignition barrel works and the noise when the key is in works. Windows, cd player, dash lights aren't working. Starter does not even try to start it. Was working perfectly when i put it away the other night. Anyone any ideas??? Quote Link to comment Share on other sites More sharing options...
stevie_b Posted February 8, 2014 Share Posted February 8, 2014 Either a bad earth, bad battery terminal connections or your starter motor contacts needs refurbishing. There's a guide on here for doing the refurb: common fault, not expensive to fix. Not sure about the cd player and dash lights not working. Everything else apart from that points to starter motor contacts. Quote Link to comment Share on other sites More sharing options...
George86 Posted February 8, 2014 Share Posted February 8, 2014 check that the connectors of cable that coming out of the distributor are not oxidized. Quote Link to comment Share on other sites More sharing options...
Ian C Posted February 8, 2014 Share Posted February 8, 2014 Check your 50amp AM1 fuse in the engine bay fuse box Quote Link to comment Share on other sites More sharing options...
Paul-90 Posted February 8, 2014 Author Share Posted February 8, 2014 The ignition isnt even turning on as well. Looked at the am1 fuse and its ok. Any other susgestions? Quote Link to comment Share on other sites More sharing options...
Batmax Posted February 8, 2014 Share Posted February 8, 2014 Hi I had a similar problem box with cable unplugged, you can find it around the glove box in my case, don't know if that box is from the car or from the alarm. Quote Link to comment Share on other sites More sharing options...
