12 galls of diesel in my mk4 jz - ge - info on my recovery.
herbiemercman
hi guys & girls, if you are a petrol head junky and love your car then the worst thing you can do is brim it with diesel. mega embarassment when you try everything on the garage forecourt and then the attendant comes out and says "are you having trouble" ? yes it just wont start ! "I know she said, you put diesel in it" ! My reaction was to tell her to "F" off, but i quickly looked at my receipt, sh-t, i have.
So the wife came out with my merc and i am towed home, for the benefit of other members who may be a dick head like me i will describe how i resolved this problem, as there are conflicting info on this site and other sites about the cures and possible consequences.
My action was to syphon the diesel from the tank, i had put the car on an incline leaning towards the filler cap, this enabled me to get 11 galls out so 1 gall remained. I then removed the fuel return scavenge pipe from the end of the fuel inj rail, and cranked for 3 or 4 mins. The fuel will only pump with cranking. I then added 500 cc's of "redex" fuel cleaner and five gallons of petrol. I then charged the battery which had run down with my previous cranking etc. I cranked the car for a few minutes and no joy, not even a cough, I had left the fuel return pipe dissconnected so figured this may stop the fuel rail from pressurising, so reconnected. After more cranking it started on two pots and i kept cranking as it would die otherwise, it eventually started on all six and you could not see the rear of the car for smoke for 4 or 5 mins, it then settled down as if nothing had happened, perfect tickover and same power delivery on a quick blast around the block. Really chuffed and the 11 galls of diesel is going in my merc, 3 lit tdi.
I did not remove the fuel cover / pump etc under the spare wheel, I felt it unnecessay and could create other problems etc. So i will run her for a while and then new plat plugs and a new 2 nd stage fuel filter cartridge, engine oil and filter as well. If i had called out the numerouse fuel recovery mobile services it would cost me £200 + £90 worth of diesel.
Hope this info helps other members, I know some may take the p-ss but i can take it now my car is ok. herbiemercman. (knucklehead).
Edited by herbiemercman
added extra text. (see edit history)
Well done, I did this in my first supra too and although I had always wondered how people could make this mistake I found out all too easy.
Only thing I would say about your method is rather than cranking it, you could have shorted linked the "fp" pin using a apaper clip or piece of wire in the diagnostics port to run the pump without cranking, sadly the brushes in these starter motors are now getting a little tired and prone for failure.
almost did this once with my skyline, fortunately noticed after 1.5 liters. filled the remaining tank with petrol and it ran fine. maybe even smother than ever. I would be careful putting that diesel in the merc as it is contaminated with petrol. Diesel in a petrol motor is embarrsing but petrol in a diesel motor melts things. Lady I used to work with filled a diesel with petrol and snapped a rod in the motor!
I have heard of people putting a little petrol in diesel on a regular basis, can't remember why but they had no problems
Really? will have to look that up. if so he'd probably be ok as it was what maybe 5 liters of petrol mixed with over 50 of diesel?
So the wife came out with my merc and i am towed home, for the benefit of other members who may be a $#@! head like me i will describe how i resolved this problem, as there are conflicting info on this site and other sites about the cures and possible consequences.
Next time open the boot. undo the cover for the fuel pump. Disconnect the fuel hose from the pump and connect a new hose to the pump then going to a bucket. Run 12v power to the battery and your done :) all fuel empty without cranking for half a day and potentially killing the starter motor
thanks for comments guys, i agree the car's own fuel pump was the right option, allthough i am hoping there will not be a next time. lol. the bit about petrol in diesel is correct, but the damage is based on overheating the combustion chambers etc, so i am looking at circa max 20% dilution:innocent: and i will add half a litre of fully synth oil, my big 7 seater bus is the indestructable td 3000 amg, indirect injection so no worries. I'm a lancashire lad from a mining town and could never throw away 11 galls of diesel. lol. Apparantly the companies who provide the wrong fuel in cars service are always buisy and never buy fuel for their own cars, suppose a perk of the job, they did not get my fuel or the £200. herbiemercman.
spelling corrections. (see edit history)
I done this years ago put petrol in a 1.9 diesel Clio it still ran with a tenner of petrol in it but very smokey I drove it to a garage my dad knew, cost me £70 to get the tank flushed out very embarrassing. Old diesels could handle this sort of thing but I don't think you'd get away with it so easy in a newer one.
