Retro fit cruise control on an N/A??
Si_s Supe
I retrofitted cruise control (and active spoiler) to my "N/A".
Add; a behind the dash bulkhead-loom to Scotts list and it's plug & play.
Unless you already have the large green connector for cruise ecu on your existing loom. I do. I think I just need the brake switch.. I cant find a part number.
I retro fitted it to mine as well. My supra did not have any of the cruise wiring.
I got connectors from a breaker and thanks to David who gave me a loom.
The only bit i still cant figure out is where to tap in for the auto gearbox drive/park switch.
Ive tested it and it works. :).
Just to ask guys - can any other Toyota/Lexus steering wheel be used to control the cruise control?
My 93 N/A has all the parts needed fitted - but has had an aftermarket steering wheel fitted, thus has no cruise control stalk.
I'd be interested to know this too. I love the standard 3 spoke wheel I currently have. Losing this is the only trade off!!
There are 2 different Supra cruise stalks. (Lexus ones look same but are different electronics)
3 spoke wheel stalk and 4 spoke wheel stalk, the matching one can be retrofitted to either stock wheel.
Ah amazing! Thank you. So I need a 3 spoke stalk and that'll fit directly onto my standard, Jspec, 3 spoke, non-airbag wheel?
Yes, if you can find one.
I couldn't, so I used one from a Lexus 3 spoke wheel and changed the circuit board inside for a 4 spoke Supra one.
Cool, thanks for the info.
Is this the grey plug I need? Rubbish pic I know, but it's under the alarm siren.
Does this mean the loom is all in place? In which case I'd just need to check I have a 4 pin brake switch, and get the motor / cable / stalk / ECU??
