Seat belt no longer retracting
rider
My driver seat belt doesn't retract unless it is encouraged to do so. It still functions fine. I'm reluctant to change out for a new one as they have date tags that can be used to corroborate the year of vehicle manufacture. So does anyone know how to get it running freely again. A simple fix like squirt ptfe here? Or is it a replacement only.
They are all getting a bit slow to retract from the ones I have seen. I got a replacement from a 97 car so the date thing didn't affect me.
These cars are getting old so I would be reluctant to accept that a car was dodgy just because the belts are from a different age of car.
H.
These belts have two retraction modes, when you unbuckle there is slightly more tension to retract. There is a solenoid that controls these two modes on the retractor itself. A short term fix to the sag you have when the belt is buckled is to remove the electrical connector on that solenoid. The belt will be tighter against your body than normal but it's better than being loose. Long term, replace them and keep twists out of them upon retraction.
Best is to replace with a new one. The plastic spindle bit that the spring winds around broke in mine. Facelift one is different to the early one as I found out. Both fit each other but early model one was built more solid and physically bigger than the facelift one. Probably due to weight saving. But as I said, if you're buying new either is good.
