Tommyd16 Posted January 28, 2014 Share Posted January 28, 2014 May sound a daft question but how do I check coolant levels? Have little expansion tank on front of radiator with a in there and check the top of the radiator and that is about full. Is this correct? Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted January 28, 2014 Share Posted January 28, 2014 Yep. Also, make sure it's not a really dirty looking reddish brown, it's bright red when new Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted January 28, 2014 Author Share Posted January 28, 2014 It's pretty red. How much should be in the tank at the front. There is just a wee bit in there Quote Link to comment Share on other sites More sharing options...
Josh Posted January 28, 2014 Share Posted January 28, 2014 It's pretty red. How much should be in the tank at the front. There is just a wee bit in there If it's a standard expansion tank, on the left hand side there are minimum and maximum levels Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted January 28, 2014 Author Share Posted January 28, 2014 So I just this needs topping up then as there was about a cm in there. How come there is another cap on the radiator? Quote Link to comment Share on other sites More sharing options...
LOGIE Posted January 28, 2014 Share Posted January 28, 2014 Look carefully at your expansion tank (plastic one) there will be a max and a min level. Keep it just under the max. Also if there is about a cm in there keep an eye on it as you may have a coolant leak. The cap on the rad is for filling after changing the radiator. Quote Link to comment Share on other sites More sharing options...
Havard Posted January 28, 2014 Share Posted January 28, 2014 I would get it topped up and check it regularly. Running without enough coolant is bad and I wouldn't put too much faith in the stock temp gauge as they are not the best. New head gasket anyone? Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted January 28, 2014 Author Share Posted January 28, 2014 Cheers topped up the expansion tank. Will keep an eye on it. Looks like I have an original radiator so it being 18years old it might need replacing Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted January 28, 2014 Author Share Posted January 28, 2014 Got no mayo any where and temp seems fine Quote Link to comment Share on other sites More sharing options...
Josh Posted January 28, 2014 Share Posted January 28, 2014 Cheers topped up the expansion tank. Will keep an eye on it. Looks like I have an original radiator so it being 18years old it might need replacing My stock radiator split after 18 years. It had been in the UK all its life though, unlike Jspecs (if that's what you have). Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted January 28, 2014 Author Share Posted January 28, 2014 Yh jspec. How much is a new rad if I need one? And best place to get it? Quote Link to comment Share on other sites More sharing options...
Scooter Posted January 28, 2014 Share Posted January 28, 2014 You may have a weak rad cap, take yours off and inspect the bit that lives in the radiator neck, it should have a nice rubber seal, for the few quid they are I'd be tempted to get a new one if you think it looks the age of the rad. Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted January 28, 2014 Author Share Posted January 28, 2014 Cheers I'll look into it Quote Link to comment Share on other sites More sharing options...
LOGIE Posted January 28, 2014 Share Posted January 28, 2014 Yh jspec. How much is a new rad if I need one? And best place to get it? "If" You need a rad get a genuine toyota one. Are you NA or TT? Manual or auto? TT ones are thicker than NA and auto cars have a built in gearbox cooler in the rad. TT rad was £330ish when I checked about 6 months ago. As already mentioned check the basics first. Rad cap etc. Oh is you passenger footwell wet? Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted January 28, 2014 Author Share Posted January 28, 2014 TT auto. Just ordered a new rad cap. Foot well is fine I think. Just bought the car last week so just thought I would check the coolant as I just realised I haven't done it yet :s Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted January 29, 2014 Author Share Posted January 29, 2014 Done abit of research on google. Some people are saying the hose going into the heater matrix can split. Can anyone put a picture up of this hose please. Weather is horrendous outside! I will have a look when its dryer Quote Link to comment Share on other sites More sharing options...
