Amber sticker on rear light
mk1its
That'll be where they have put the rear fog light, it's usually clear because they j-sepcs have two reverse lights. Most people put in a red bulb... but I guess an amber sticker works too. :p
Amber sticker can't work as it's the wrong colour for a fog light and against the law.
I'm surprised that has passed any MOT with that on
Good point, on my old supra someone had sprayed the old clear bulb with red paint. That came out as a sort of dull orange, didn't pass it's MOT.
I just wired up a relay so that 2 of my rear lights (1 each side) would function as both fog and brake light, when fog was off all 4 rear lights would work as brake, when fog on the 2 inner without reflector would be lit and the remaining 2 would come on under braking. Cost about £5 and took about 15mins, meant I kept both of my reverse lights as i have OCD like that :D
i had to sort out my foglight when i bought my 2nd supra , the bloke before me had painted the bulb red so that was an easy fix, next the i reconnected the reverse wire that had been cut to wire in the fog light so now i had the 2 reverse lights working then on the red tail light next to there is a double element bulb so i cut the wire and daisy chained it to the other side too and hey presto fog lights on both sides and reverse lights on both sides .
if something has been glued to the lens you might need a new rear light
It's worth noting if you put a fog light in the right side reverse light it "might" still fail an MOT as the fog light has to be a certain distance from a taillight. Im not sure on this distance in mm's but that's why UK spec cars rear light layout is different. It all depends on how clued up or strick you MOT man is.
