Guest hoylegj Posted January 26, 2014 Share Posted January 26, 2014 Hi, anyone had problems with the aerial causing flat battery's?, the aerial has stopped going down and there seems to be a constant current draw of 3 amps ish, (shown by the battery charger) Many thanks Geoff Quote Link to comment Share on other sites More sharing options...
Coleboy Posted January 26, 2014 Share Posted January 26, 2014 How can a battery charger show a drain, only a muti meter connected in line can show a drain, the 3 amps shown on the charger is what it putting in.......... Have you disconnected the mast?? Quote Link to comment Share on other sites More sharing options...
Guest Roger NE Posted January 26, 2014 Share Posted January 26, 2014 Do you mean your Battery Charger is showing that it is delivering 3 Amps when connected to your battery? Just because the battery is taking 3A from the charger DOESN'T mean something on the car is drawing 3A from the battery. In answer to your question about the aerial, I think it's wired AFTER your ignition switch. However, to discover what the current drain on your battery is with everything off, you need to disconnect one of your battery terminals and connect a Multimeter (on a Current range) inbetween to measure the current. I presume you have some kind of Alarm/Immobilser that will be taking SOME current . . . see what figure you get. EDIT: Sorry, Coleboy's post was while I was writing this one! Quote Link to comment Share on other sites More sharing options...
