coilover help ish
JK90
The stock lower arms have a certain amount of camber adjustment, depends on how low you want to go, retard, impractical low or just a small drop.
This. Depends what you're after and why; looks or handling?
I think the adjustable camber is on the top mount, I want be going retard low maybe to the tops of tyre, bc seem to pop up a lot on here for coilovers but there's only one set you can get for the supra I think
Just out of interest why do you want to ruin the handling of a great car? By making it look like it dropped out of the sky and buckled the underside?
Mad scene points innit? I like a low car, but not to the point of having to worry about every speed ramp or raised drain cover.
Dodgydodds, Id disagree, personally for me rubber top mounts give a much better ride.
