JK90 Posted January 26, 2014 Share Posted January 26, 2014 looking at coilovers and was looking to buy with adjustable camber on the coilovers or should I not? I have double wishbone suspension so would I need adjustable camber arms or what. thanks Quote Link to comment Share on other sites More sharing options...
JK90 Posted January 26, 2014 Author Share Posted January 26, 2014 no help? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 26, 2014 Share Posted January 26, 2014 The stock lower arms have a certain amount of camber adjustment, depends on how low you want to go, retard, impractical low or just a small drop. Also bumping a thread less than 2 hours? Quote Link to comment Share on other sites More sharing options...
safcdixon Posted January 26, 2014 Share Posted January 26, 2014 Go with the tried and tested coilovers imo Teins, bc, h+r, what type are they? Ive never seen any with adjustable camber before Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted January 26, 2014 Share Posted January 26, 2014 The stock lower arms have a certain amount of camber adjustment, depends on how low you want to go, retard, impractical low or just a small drop. This. Depends what you're after and why; looks or handling? Quote Link to comment Share on other sites More sharing options...
JK90 Posted January 28, 2014 Author Share Posted January 28, 2014 I think the adjustable camber is on the top mount, I want be going retard low maybe to the tops of tyre, bc seem to pop up a lot on here for coilovers but there's only one set you can get for the supra I think Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 28, 2014 Share Posted January 28, 2014 They don't have camber top mounts, unless you can get them separately. As stated the camber adjustment is through the lower arm, but you can get camber adjustable top arms from eBay etc. Quote Link to comment Share on other sites More sharing options...
LOGIE Posted January 28, 2014 Share Posted January 28, 2014 I think the adjustable camber is on the top mount, I want be going retard low maybe to the tops of tyre, bc seem to pop up a lot on here for coilovers but there's only one set you can get for the supra I think Just out of interest why do you want to ruin the handling of a great car? By making it look like it dropped out of the sky and buckled the underside? Quote Link to comment Share on other sites More sharing options...
DODGYDODDS Posted January 28, 2014 Share Posted January 28, 2014 I run meister r's. very good coilover for the money, and very compliant on uk roads. I would go meister r or HSD over bc, just for the pillow ball top mounts. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 28, 2014 Share Posted January 28, 2014 Just out of interest why do you want to ruin the handling of a great car? By making it look like it dropped out of the sky and buckled the underside? Mad scene points innit? I like a low car, but not to the point of having to worry about every speed ramp or raised drain cover. Dodgydodds, Id disagree, personally for me rubber top mounts give a much better ride. Quote Link to comment Share on other sites More sharing options...
DODGYDODDS Posted January 29, 2014 Share Posted January 29, 2014 That's the thing swampy the m-r's are very compliant, I've had bc and I find do the Meisters a superior product. Being uk based is appealing to. Quote Link to comment Share on other sites More sharing options...
Gpro Posted January 29, 2014 Share Posted January 29, 2014 bc racing are brilliant Quote Link to comment Share on other sites More sharing options...
JK90 Posted January 29, 2014 Author Share Posted January 29, 2014 I don't want it stupidly low it will be sitting above the tyres, it has teins on at the moment and it came with them but the fronts are ceased so want to replace them Quote Link to comment Share on other sites More sharing options...
Dan_Q Posted January 31, 2014 Share Posted January 31, 2014 camber top mounts??? that doesn't work with double wishbone suspension, hence why you can't get them. as said above its on the cam bolts in the lower arm or aftermarket arms to change the camber. Quote Link to comment Share on other sites More sharing options...
