Guest Balf86 Posted January 26, 2014 Share Posted January 26, 2014 Started off ocasionally as i braked now its more or less all the time. Is this likely to be a loose handbreak? The hand break does feel a little loose. Also how easy is it tighten . I hav a 3l non turno auto Quote Link to comment Share on other sites More sharing options...
Supra Kong Posted January 26, 2014 Share Posted January 26, 2014 It's called drifting!!! Quote Link to comment Share on other sites More sharing options...
Guest Balf86 Posted January 26, 2014 Share Posted January 26, 2014 Any serious responses? Quote Link to comment Share on other sites More sharing options...
safcdixon Posted January 26, 2014 Share Posted January 26, 2014 Is it the handbrake light or the big warning triangle? If the latter it could be low fluid, if its the normal handbrake light it could be a loose switch under the centre console Quote Link to comment Share on other sites More sharing options...
Guest Balf86 Posted January 26, 2014 Share Posted January 26, 2014 Its the trinagle and the ((!)) - - - Updated - - - Fluid level looks good Quote Link to comment Share on other sites More sharing options...
bananasupra Posted January 26, 2014 Share Posted January 26, 2014 Funny that!! I have the same problem could it be low pads ? On the rear Anyone ?? Quote Link to comment Share on other sites More sharing options...
bananasupra Posted January 26, 2014 Share Posted January 26, 2014 Do you get the triangle and the hand brake light on at the same time ? Quote Link to comment Share on other sites More sharing options...
reeceu Posted January 26, 2014 Share Posted January 26, 2014 it is probably the fluid level. it only has to be off a tiny amount and it will flag up. worth just putting it on max just in case and normally solves the issue. Quote Link to comment Share on other sites More sharing options...
listy Posted January 26, 2014 Share Posted January 26, 2014 Common problem. Top up the brake fluid. It may look full, but it is VERY sensitive. Top it up to just above the full mark. Quote Link to comment Share on other sites More sharing options...
Guest Balf86 Posted January 26, 2014 Share Posted January 26, 2014 Ok willdo that however can someone confirm if the rear pads are linked to thew arning lights? Think mine are a little worn wondering if that effects it? Hiwever will try the fluid advice Quote Link to comment Share on other sites More sharing options...
bananasupra Posted January 26, 2014 Share Posted January 26, 2014 Thanks guys........... Quote Link to comment Share on other sites More sharing options...
