oh DEAR!!!!!!!!!
Mid_lifecry_sis
:( :mad: :conf: :stupid:
I found out last week that I was running only TURBO 1. Friday this was fixed with a vacume pipe reattachment.
Sh*t the car is 600cc bike beater.
2 MINUTES FROM HOME. it died on me. Error 13 and 41.
Before she dies once out of safe mode via a reboot, the rev needle goes a little loopy and then the warning Triangle and engine light appears and the engines cuts.
Why for three months has she been OK and now appars following the No 2 T does this happen? heard of this before? Is this coinsidence? Any bright ideas?
Don't care how much. Just missed a sunny weekend where bikes deserve a thrashing and my car is dead. PS: Sounds a little tinny or metalic from engine,,,,, maybe - could just be me.
Going to put her back in to shop for fix but don't wanna be stung and want to understand some of the feed back.
Really appreciate all the thoughts and help here.:( :mad: :conf: :stupid:
an instance where my friends jap spec did a simular thing, it turned out the imprellar shattered through running it on 1.25 bar for long periods. i may be wrong about this , but he replaced both turbos for standard uk spec ones, which were likely not to explode again.
Iam no expert , you best off asking leon or some other expert on the board. ask me about computers ill some ideas there :p
Check your Throttle position sensor connection ..
You have checked the error codes in the resources section ?
41 is TPS
13 is ECU not receiving a signal ... check earths and all underbonnet connections
Could well have blown an IC pipe off with the new boost levels . Check these first, before booking it in.....
Cheers for the error code advice mate, will check under the bonnet.
Shame this web site dosen't have a garage somewhere for members!
140 sup's on this site alone at £100 per annum say, membership plus reduced fee's for breakdown - nice bit on the side! Link this bodyshop and body kits, plus tuning !!!!!!!
Cheers for a FAB site!
