Supradk Posted January 25, 2014 Share Posted January 25, 2014 (edited) Hi im looking for a new set of UK rear brake disc. found these on ebay but what do you guys think? in the description it says they are 16,5 in thickness but oem are 16mm? http://www.ebay.co.uk/itm/300809076108?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 want some cheap disc but they still need to be good quality? cheers kåre Edited January 25, 2014 by Supradk (see edit history) Quote Link to comment Share on other sites More sharing options...
Josh Posted January 25, 2014 Share Posted January 25, 2014 No link Quote Link to comment Share on other sites More sharing options...
Supradk Posted January 25, 2014 Author Share Posted January 25, 2014 here you go Quote Link to comment Share on other sites More sharing options...
Nic Posted January 25, 2014 Share Posted January 25, 2014 Cheap grooved and drilled discs are prone to cracking, OEM Toyota discs are hard to beat in terms of quality and value for money. http://www.mkivsupra.net/vbb/showthread.php?294186-Cracks-in-brake-disks-Safe-to-use&highlight=cracked+discs Quote Link to comment Share on other sites More sharing options...
Supradk Posted January 25, 2014 Author Share Posted January 25, 2014 its not that good :-) 3G are even more expensive then the ones i found? :-) Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 25, 2014 Share Posted January 25, 2014 Stock discs from Toyota are the way to go unless your doing very serious track day use Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 25, 2014 Share Posted January 25, 2014 Stock discs from Toyota are the way to go unless your doing very serious track day use But they're not cheap though Dunc Quote Link to comment Share on other sites More sharing options...
Iky Posted January 26, 2014 Share Posted January 26, 2014 Get adl blueprint ones from your local motorfactor Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted January 26, 2014 Share Posted January 26, 2014 Get adl blueprint ones from your local motorfactor +1 euro car parts supply pagid discs very reasonably Or, speak to Trevor at tcb parts for oem parts, cheaper than Toyota direct! However, id be surprised if 'genuine' Toyota discs, aren't just rebranded blueprint parts Quote Link to comment Share on other sites More sharing options...
Nic Posted January 26, 2014 Share Posted January 26, 2014 However, id be surprised if 'genuine' Toyota discs, aren't just rebranded blueprint parts The Toyota discs are made and boxed in Japan. Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted January 26, 2014 Share Posted January 26, 2014 Doesn't mean they're not blueprint though. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 26, 2014 Share Posted January 26, 2014 However, id be surprised if 'genuine' Toyota discs, aren't just rebranded blueprint parts You've got that arse about face, Blueprint parts are knock off Toyota and other OEM parts. Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted January 26, 2014 Share Posted January 26, 2014 Blueprint parts are considered to be as good as 'oem' parts in many ways. But, what I meant was, id doubt Toyota actually make their own brake discs, so the company who makes them just brands them to who they supply to. How do we know that pagid/blueprint/oem parts aren't all made in the same factory somewhere? Quote Link to comment Share on other sites More sharing options...
