gregsupra4 Posted August 25, 2005 Share Posted August 25, 2005 Hi All, I trust everyone is in good health ??? Right to my point I need some advise !!! Can someone please tell me if there is a way that I can add ABS to my car as I do not have it at the moment. The reason behind this is that I would like to try Racelogics launch control system. Or if anyone knows of another way that I can get the same result please feel free to tell. Thank You. Quote Link to comment Share on other sites More sharing options...
gregsupra4 Posted August 25, 2005 Author Share Posted August 25, 2005 Come on someone must be able to help with this !!!!!!! Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted August 25, 2005 Share Posted August 25, 2005 Why have you not got abs???? yours is a 95 so should have it?? Quote Link to comment Share on other sites More sharing options...
IanK Posted August 25, 2005 Share Posted August 25, 2005 Is your car an auto? if so, i didn't think you could use the Launch Control function with an auto? Quote Link to comment Share on other sites More sharing options...
gregsupra4 Posted August 25, 2005 Author Share Posted August 25, 2005 Really I do not know why it has not got ABS the paperwork says it is a 1995 but could be a late 1994 it's an import so who knows, it is also manual. Just as a point on the vin plate in the engine bay is all the relevent information but where it say's trans/axle it only shows the trans number no axle number, is this something others have. Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted August 25, 2005 Share Posted August 25, 2005 It should be ABS mate, have you locked up in it yet???? how do you know its not?? You ,might find it is could be wrong though Quote Link to comment Share on other sites More sharing options...
Alex Posted August 25, 2005 Share Posted August 25, 2005 can you give us all the VIN plate details? Might be able to sort out what it is. Quote Link to comment Share on other sites More sharing options...
Ian C Posted August 25, 2005 Share Posted August 25, 2005 A photo of the engine bay would do! -Ian Quote Link to comment Share on other sites More sharing options...
gregsupra4 Posted August 25, 2005 Author Share Posted August 25, 2005 Guy's My Engine bay sorry about the pic but as you will see in the red circle there is only the carbon can. Quote Link to comment Share on other sites More sharing options...
gregsupra4 Posted August 25, 2005 Author Share Posted August 25, 2005 Really having a blonde day today forgot to add the picture Quote Link to comment Share on other sites More sharing options...
Mike Posted August 25, 2005 Share Posted August 25, 2005 I thought it was only late 96 facelift models that had ABS? Quote Link to comment Share on other sites More sharing options...
Faye Posted August 25, 2005 Share Posted August 25, 2005 I thought it was only late 96 facelift models that had ABS? My understanding was that ABS was standard on all TTs and an option on the NA's Quote Link to comment Share on other sites More sharing options...
Ian C Posted August 25, 2005 Share Posted August 25, 2005 So no fat ABS pump unit there then? The piccy is too blurry to make out 100% one way or the other, plus you drew the red line over that area as well -Ian Quote Link to comment Share on other sites More sharing options...
gregsupra4 Posted August 25, 2005 Author Share Posted August 25, 2005 Guys, Trust me there is no ABS unit there. Still need an answer to my first question " Can it be fitted " Quote Link to comment Share on other sites More sharing options...
Ian C Posted August 25, 2005 Share Posted August 25, 2005 Anyway, if you have no pump then you have no ABS, and retofitting it would probably be an epic nightmare and expensive too. You can just retrofit the ABS sensors for RLTC purposes only though -Ian Quote Link to comment Share on other sites More sharing options...
gregsupra4 Posted August 25, 2005 Author Share Posted August 25, 2005 Hi Ian, Please could you expand on the sensor bit. Quote Link to comment Share on other sites More sharing options...
Nic Posted August 25, 2005 Share Posted August 25, 2005 As Ian says you can just fit the sensors so you can fit the RLTC. Greg if you need some new sensors organising, let me know and I'll get price for you. If you want to fit complete ABS system I could have a chat with my supplier and see what would be involved, parts and labour wise. Quote Link to comment Share on other sites More sharing options...
gregsupra4 Posted August 25, 2005 Author Share Posted August 25, 2005 Thanks Nic, I take it that RLTC unit would have the feeds for the sensors and it would be a matter of just joining them up ???? Also does that mean that I have the sensor holders already on my brakes ??? Quote Link to comment Share on other sites More sharing options...
Ian C Posted August 25, 2005 Share Posted August 25, 2005 Christ knows Budget for four abs hubs + sensors + wiring looms for the sensors (v. important as they are shielded). That plus some custom wiring for power + ground etc. and you can plumb the sensors straight into the RLTC unit's sensor inputs. You won't have ABS but you will have God's own traction control. If your research shows you have holes in the hub for ABS sensors and the ABS sensor ring fitted (important that ) then you save cash, hurrah. -Ian Quote Link to comment Share on other sites More sharing options...
gregsupra4 Posted August 25, 2005 Author Share Posted August 25, 2005 Thanks Ian. Quote Link to comment Share on other sites More sharing options...
Nic Posted August 25, 2005 Share Posted August 25, 2005 If your research shows you have holes in the hub for ABS sensors and the ABS sensor ring fitted (important that ) then you save cash, hurrah. I'd have thought T would use the same hubs and just block the holes but then again knowing how they chop and change every other part/number then perhaps not. Might be worth contacting Chrs Wilson he may well know. I'm sure I've read on here of members who have retro fitted the sensors, Greg maybe worth doing a search and seeing if you find any relevant threads. I'll also have a chat with my supplier tomorrow, as he should be able to tell me what would be required. Quote Link to comment Share on other sites More sharing options...
Soop Dogg Posted August 25, 2005 Share Posted August 25, 2005 OR....... Racelogic used to do their own devices for non-abs cars. Consists of something that straps onto the driveshafts with teeth (high/low spots) on them and some sensors that fit onto the suspension (so they travel up and down with the driveshafts) and read the pulses from the things on the shafts. Not sure if they still do these, but I know they used to. You'd have to ask them. Quote Link to comment Share on other sites More sharing options...
