Wheel alignment
Guest suprageek
Guest suprageek
I've recently noticed that my front tyres are wearing on the inside, the car is on 18" rims and is lowered on H&R coilovers, I've decided to get the alignment done what I want to know is does anyone have the settings for 18" rims and lowered as the guy that's going to do it has asked me if I know them, thanks in advance
He does have access to the stock settings Ian but the car is lowered and on bigger rims so I imagine the settings are different
The alignment should still be the same :) Doesn't matter how big the rims are or how lowered it is, the wheels still need to have the same caster, camber, toe in toe out etc. or it'll handle differently (and usually poorly; tramlining and inner tyre edge wear are the immediate suspects). You might not actually be able to achieve stock settings because of the amount it's lowered, but that's a different issue.
Where could I find the stock settings for a NA?
Guest looneytoones
if you can get a full geo check on it, not with the laser track but with the camera track, it's a thousand times more accurate and it has the settings stored in its memory, it can tell you if you camber caster and aslo toe in-out needs adjusting and how much by even on the rear
