darren0405 Posted January 24, 2014 Share Posted January 24, 2014 Hi I'm having a bit of trouble getting the tailgate bottom screws out I've cut all the rubber away and tried a small blow torch but to no avail then tried wd40 same again ,now heads are wearing out what I might do I cut and drill them out as I've just bought new rubbers my question is does anyone know what size screws I need to replace them with?? Many thanks Darren Link to comment Share on other sites More sharing options...
SPG Posted January 24, 2014 Share Posted January 24, 2014 If you are going to replace them, then consider installing some allen bolts instead. If the heads are totally gone, you might wanna cut a notch out the heads with a dremel, that should give you the extra purchase you need to get the screws out. Link to comment Share on other sites More sharing options...
wile e coyote Posted January 24, 2014 Share Posted January 24, 2014 as above Link to comment Share on other sites More sharing options...
clay Posted January 24, 2014 Share Posted January 24, 2014 Im shore the screws are m6x20.If you put some stainless steel ones in.They wont go rusty again. Link to comment Share on other sites More sharing options...
darren0405 Posted January 25, 2014 Author Share Posted January 25, 2014 Thanks for the advice fellas Link to comment Share on other sites More sharing options...
