Tailgate rubber Screws
darren0405
Hi
I'm having a bit of trouble getting the tailgate bottom screws out I've cut all the rubber away and tried a small blow torch but to no avail :( then tried wd40 same again ,now heads are wearing out what I might do I cut and drill them out as I've just bought new rubbers my question is does anyone know what size screws I need to replace them with??
Many thanks
Darren
If you are going to replace them, then consider installing some allen bolts instead.
If the heads are totally gone, you might wanna cut a notch out the heads with a dremel, that should give you the extra purchase you need to get the screws out.
