Tommyd16 Posted January 23, 2014 Share Posted January 23, 2014 Just got a Thor speed convertor. Found a guide on here but my unit has different colored wires. Can anyone help please!? Quote Link to comment Share on other sites More sharing options...
rider Posted January 23, 2014 Share Posted January 23, 2014 Just got a Thor speed convertor. Found a guide on here but my unit has different colored wires. Can anyone help please!?http://img.tapatalk.com/d/14/01/23/u9udubeh.jpg Have you tried contacting them direct? mailto:[email protected] Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted January 23, 2014 Author Share Posted January 23, 2014 Yes got in touch and they emailed me a wiring diagram. All sorted now. Just incase anyone else needs it; Quote Link to comment Share on other sites More sharing options...
Guest pwings18 Posted January 23, 2014 Share Posted January 23, 2014 Yes but this way odometer ll still run in kms. if you want odo to run in miles wiring is not good. Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted January 23, 2014 Author Share Posted January 23, 2014 Kms for miles is fine. Means it will always be in km so easy to work out. Quote Link to comment Share on other sites More sharing options...
Guest Roger NE Posted January 23, 2014 Share Posted January 23, 2014 Aha - is that why the Main ECU requires a Speed Signal on the Pink wire - so it can LIMIT the top speed? Originally I left this wire disconnected when fitting a 2JZ-GE in my Mk 3 . . . but kept getting an Engine Fault Light (and Fault Code said no speed signal) So what speed is a JDM 2JZ-GE normally limited at? I don't think Speed Limiting will be a problem, as the signal I have fed from the Mk3 dash is MUCH slower pulses . . . but it keeps the ECU from showing an error (and apologies for hi-jacking your thread!) Quote Link to comment Share on other sites More sharing options...
Guest pwings18 Posted January 23, 2014 Share Posted January 23, 2014 Like all jdm engines I presume : 180km/h Quote Link to comment Share on other sites More sharing options...
Guest Roger NE Posted January 24, 2014 Share Posted January 24, 2014 So presumably, if you guys fit a 8:5 downscaler to make the Speedometer read in MPH, and fed THAT signal to the main ECU too, it would just limit the top speed to 180 mph? Quote Link to comment Share on other sites More sharing options...
