ibby Posted January 22, 2014 Share Posted January 22, 2014 ` I dont have a Supra so I am hoping this gets moved to the project section anyway I have owned my Toyota Aristo for around two years and have decided to make it alittle more ecnomical by converting it into a LPG. I am trying to downsize my existing fleet size so I can unlock some of the money stuck in the cars. Having looked at LPG installers locally to me in Leeds, Manchester, sheffield etc I settled with a guy whos work I had seen on an LPG forum. He has worked on GS/LS430 cars and the work he has done is 100%, looks clean and comes higly recomended. His contact details are; Toby http://www.independentautogas.co.uk/ Dont let the simplistic website put you off, he knows his stuff! V-Power costs me somethings 1.40+ a litre to fill up. Its generally 98 ron and LPG is 108 RON to 115 RON. The Toyota Aristo comes with the same running gear / engine has the supra twin turbo. I have decided on having the kit to be based around 450HP and currently its in stock form. I cant wait to go BPU! Here the specfication of the stuff hes installing 2x Bigas vaporizers (these can support 220HP each) OR Each of the above vaporizers will be wired to 3 LPG injectors each. 6x HANA A Injectors, these can support from 60HP to 75HP on each cylinder. KING ECU with AEB firmware. 8MM gas flow pipe from the back to the front of the car (normally 3mm, or 6mm is installed) Electronic flash lube injected to each cylinder. 88L LPG tank, that will fill up around 70L. He will ovbiously seal the spare wheel area, where he will "bash the panels" out alittle to make the larger tank fit. Quote Link to comment Share on other sites More sharing options...
ibby Posted January 22, 2014 Author Share Posted January 22, 2014 Some Pictures of the install so far.. LPG Filler installed in the middle of the bumper - Now can fill up from any side http://ibby.co.uk/car/lpg/LPGfillter.JPG LPG Tank Connected up http://ibby.co.uk/car/lpg/lpgtankconnected.jpg Boot space covered up http://ibby.co.uk/car/lpg/Bootwithtankcovered.JPG Will have some more pictures in a short while! Quote Link to comment Share on other sites More sharing options...
ibby Posted February 11, 2014 Author Share Posted February 11, 2014 Picked the car up... drove it for about 150 miles first impressions. 1 - Kit hasbeen installed to a good Standard. 2 - Drives really well! 3 - No loss of power, goes on gas very good. 4 - Does not drop to petrol when on WOT. Quote Link to comment Share on other sites More sharing options...
ibby Posted February 11, 2014 Author Share Posted February 11, 2014 http://ibby.co.uk/car/lpg/IMAG0311.jpg http://ibby.co.uk/car/lpg/IMAG0312.jpg http://ibby.co.uk/car/lpg/IMAG0313.jpg http://ibby.co.uk/car/lpg/IMAG0314.jpg http://ibby.co.uk/car/lpg/IMAG0315.jpg http://ibby.co.uk/car/lpg/IMAG0316.jpg http://ibby.co.uk/car/lpg/IMAG0317.jpg http://ibby.co.uk/car/lpg/IMAG0318.jpg http://ibby.co.uk/car/lpg/IMAG0319.jpg http://ibby.co.uk/car/lpg/IMAG0320.jpg http://ibby.co.uk/car/lpg/IMAG0321.jpg http://ibby.co.uk/car/lpg/IMAG0322.jpg http://ibby.co.uk/car/lpg/IMAG0323.jpg http://ibby.co.uk/car/lpg/IMAG0324.jpg http://ibby.co.uk/car/lpg/IMAG0325.jpg http://ibby.co.uk/car/lpg/IMAG0326.jpg http://ibby.co.uk/car/lpg/IMAG0327.jpg http://ibby.co.uk/car/lpg/IMAG0328.jpg Quote Link to comment Share on other sites More sharing options...
ibby Posted February 11, 2014 Author Share Posted February 11, 2014 LPG TANK SIZE I have an 88L tank which can be filled upto 70L. My tank is a single hole and was unable to keep up the gas demand when the car was under WOT. Its single size because of the capacity of the tank. You could install a 4 hole tank but the spare wheel whell can only fit a 65L with a fill of around 50L. The Flux capacitor and the extra lengths of gas pipe ensure the supply needed by the two bigas reductors can be met when you decide to pound it and the 2nd turbo comes on. How does it drive I have compared the car on petrol and LPG and it drives very good on LPG. Its not low on power at all and actually feels like it has alittle more umph to it. When does it switch over Once the temp reaches 40c, which is pretty quick it automatically shifts to gas. About 2 / 3 minutes or upto 1 mile of driving. Would I recomend the installer? Yes defo, Hes over 140 miles from me but I will chose him again. I am already thinking about converting an IS200 I have. He knows what he is doing, takes his time and does it right. Quote Link to comment Share on other sites More sharing options...
verossa Posted February 12, 2014 Share Posted February 12, 2014 "Electronic flash lube injected to each cylinder." Why does it needs this? Quote Link to comment Share on other sites More sharing options...
ibby Posted February 12, 2014 Author Share Posted February 12, 2014 verossa said: "Electronic flash lube injected to each cylinder." Why does it needs this? To prevent valve seat recession. Quote Link to comment Share on other sites More sharing options...
dandan Posted February 12, 2014 Share Posted February 12, 2014 Interesting. I'm (kind of) thinking about buying a Landcruiser Amazon....with the 4.7L V8. Lovely smooth comfortable motor but LPG is a must for any sort of sensible economy. Can you tell me what sort of mpg you get with petrol and also with LPG under similar driving conditions? Quote Link to comment Share on other sites More sharing options...
scott87 Posted February 12, 2014 Share Posted February 12, 2014 Can I ask what sort of price this was out of interest. Pm me if you prefer. Quote Link to comment Share on other sites More sharing options...
ibby Posted February 12, 2014 Author Share Posted February 12, 2014 dandan said: Interesting. I'm (kind of) thinking about buying a Landcruiser Amazon....with the 4.7L V8. Lovely smooth comfortable motor but LPG is a must for any sort of sensible economy. Can you tell me what sort of mpg you get with petrol and also with LPG under similar driving conditions? dandan said: Interesting. I'm (kind of) thinking about buying a Landcruiser Amazon....with the 4.7L V8. Lovely smooth comfortable motor but LPG is a must for any sort of sensible economy. Can you tell me what sort of mpg you get with petrol and also with LPG under similar driving conditions? Well, I used to put £40 in the car and do around 135 to 150 miles a week. The norm for the Aristo is 20MPG and lower depending on how you drive it. I had a full tank of LPG, around 70L and so far I have managed to do 200 miles in it. Thats 150 miles "around" national speed limit and the rest locally. It still has fuel in the tank, the gauge is alittle irratic and needs to settle down, I think around 70>100 miles is still in the tank. Assuming it does take the full 70L and at 20MPG / 4.5*70 gives me around 300 miles to a tank. and at 65p a Litre it costs 50£ to fill up. Them days of poor single point LPG kits have long gone, now its multi point injection, injector technology has moved on, now have proper ECUS to map the cars I dont feel the car down on power, drives well. I floor it and it goes balistic like on petrol. I am pretty sure its doing the same MPG, if not pretty dam close. Quote Link to comment Share on other sites More sharing options...
ibby Posted February 12, 2014 Author Share Posted February 12, 2014 (edited) scott87 said: Can I ask what sort of price this was out of interest. Pm me if you prefer. I am sure Toby wont mind Paid 1400£ all in. I have had the best Kit installed by a top guy. (i am not on comission based selling)! edit 1400+flux cap and some gas. Edited February 12, 2014 by ibby (see edit history) Quote Link to comment Share on other sites More sharing options...
Big Supes Posted February 12, 2014 Share Posted February 12, 2014 I did LPG conversions for a job briefly. It was pretty new back then... I had to sign a non disclosure agreement as we were working with 2 stroke engines as well. We set a speed record for a boat powered by LPG. Quote Link to comment Share on other sites More sharing options...
ibby Posted February 12, 2014 Author Share Posted February 12, 2014 Big Supes said: I did LPG conversions for a job briefly. It was pretty new back then... I had to sign a non disclosure agreement as we were working with 2 stroke engines as well. We set a speed record for a boat powered by LPG. what made you stop Quote Link to comment Share on other sites More sharing options...
scott87 Posted February 12, 2014 Share Posted February 12, 2014 Has there not been issues with toyotas and LPG or is that just Chinese whisper nonsense? Quote Link to comment Share on other sites More sharing options...
Big Supes Posted February 12, 2014 Share Posted February 12, 2014 ibby said: what made you stop Bit of a long story, but before the conversions I was working for a powerboat team which was funded solely by one guy. The LPG conversions was a small operation on the side so when the powerboat team came to a close, I was offered a job doing the LPG conversions. I did it for a while, but jumped back on the powerboats with Honda when the opportunity presented itself. Quote Link to comment Share on other sites More sharing options...
ibby Posted February 12, 2014 Author Share Posted February 12, 2014 scott87 said: Has there not been issues with toyotas and LPG or is that just Chinese whisper nonsense? I think what your reffering to lack of lubrication of the valves / seat recession. Flash lube injected into the head should prevent that Quote Link to comment Share on other sites More sharing options...
ibby Posted February 12, 2014 Author Share Posted February 12, 2014 Big Supes said: Bit of a long story, but before the conversions I was working for a powerboat team which was funded solely by one guy. The LPG conversions was a small operation on the side so when the powerboat team came to a close, I was offered a job doing the LPG conversions. I did it for a while, but jumped back on the powerboats with Honda when the opportunity presented itself. since you have done conversions before, what do you think of my converted car Quote Link to comment Share on other sites More sharing options...
verossa Posted February 12, 2014 Share Posted February 12, 2014 ibby said: I think what your reffering to lack of lubrication of the valves / seat recession. Flash lube injected into the head should prevent that By valve seat recession do you mean wear on the valve seats? Why is this a problem with LPG, higher temperatures or something else? There's no lube in petrol so I can't see why you need it for LPG. Quote Link to comment Share on other sites More sharing options...
scott87 Posted February 12, 2014 Share Posted February 12, 2014 ibby said: I think what your reffering to lack of lubrication of the valves / seat recession. Flash lube injected into the head should prevent that Brill thanks very much for clearing up a very vague question with a simple answer Quote Link to comment Share on other sites More sharing options...
ibby Posted February 12, 2014 Author Share Posted February 12, 2014 verossa said: By valve seat recession do you mean wear on the valve seats? Why is this a problem with LPG, higher temperatures or something else? There's no lube in petrol so I can't see why you need it for LPG. Yes sumat like that, although I am not 100% sure http://www.tinleytech.co.uk/acatalog/FlashLube.html - - - Updated - - - scott87 said: Brill thanks very much for clearing up a very vague question with a simple answer Not a problem Quote Link to comment Share on other sites More sharing options...
ibby Posted February 23, 2014 Author Share Posted February 23, 2014 just wanted to clear the MPG stuff up.. so here it comes. My tank is 88L and - a 20% fill up I should be able to fill up around 70L. Today I decided to fill the tank after doing 275 miles and it cost me 44.48£ LPG price was 0.69 and i managed to put 63.63L before the pump started to click off. MPG average is 19.39, covering 275 miles using 14.18 gallons of fuel. So I may have an average range of 300 Miles out of LPG. I have done around 195 miles on the motorway and the rest is local. I am sure my old GS430 came with a 70L tank, assuming the Aristo has the same tank size and V=power/ premium fuel 70*1.30 =91£ 70*1.40=98£ Quote Link to comment Share on other sites More sharing options...
