Ignition Coil
Guest Roger NE
Guest Roger NE
On the Ignition Coil (on an N/A) there is the main black connector . . . but what is the grey connector that is bolted to the bracket underneath?
Could it possibly be the Noise Suppressor?
(I was just going to add one to my 2JZ-GE install in my Mk3 Supra . . . but wondered if there's already one there?)
Hope somebody can help.
Guest Roger NE
It has two wires going to it . . . that's why I figured it might just be the Suppression decoupling capacitor.
The thin bit of loom coming from near the distributor splits into two . . . one branch goes to the black HT Coil connector (just 2 wires), the other goes to this grey connector mounted under the Coil (2 wires).
Guest Roger NE
Thanks Lyndon.
And I realise that Chris - the capacitor is there to decouple the RF spikes on the ignition coil supply.
I wasn't planning to remove it - I was going to wire one in (from my 7M engine), but then realised that there might already be one there !
Many thanks.
Edited by Roger NE (see edit history)
