ripped_fear Posted January 21, 2014 Share Posted January 21, 2014 (edited) Hi all I started my LEDs on the interior a few weeks back now and had the AC unit done by a mate. However i have a couple of issues, The first is intermittently nothing on the ac unit is illuminating when the head lights are off, however when they are on it all lights up as it should. This could just be due to a connector coming out slightly as it seemed to work for the first day it was fitted? However the problems I'm here to ask about are, the lights behind the pictures on the ac unit seem to be 'yellowed' very much so, but when the case wasnt on the ac unit the LED's are lighting up a very bright white collour. Could this be down to discolored buttons? i know it can be a problem for them to yellow however ive never seen it cause an issue with dimming the light and it didn't seem to prove an issue when stock bubs where in place, also when everything is off they don't look that bad. Problem two is on the speed-o the mph gauge still seems to have a green tint to it where as the revs are lighting up bright white. My car only has a speedo overlay on it to show the mph not kph so it only reads to 120ish could this be the cause to the dis coulouring? Any help would be greatly appreciated. Thanks Edited January 21, 2014 by ripped_fear (see edit history) Quote Link to comment Share on other sites More sharing options...
FOSTA Posted January 21, 2014 Share Posted January 21, 2014 When I done mine I read loads of posts on the supraforums about the buttons looking very yellowish when fitting the white led's. Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted January 21, 2014 Share Posted January 21, 2014 You can buy new buttons from Toyota, they just pop off. Should help Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted January 22, 2014 Author Share Posted January 22, 2014 Yeah cheers maybe I shall order a set then, I know there on here somewhere but does anyone know the part numbers? Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted January 23, 2014 Author Share Posted January 23, 2014 bump for part numbers and other ideas. Quote Link to comment Share on other sites More sharing options...
heckler Posted January 23, 2014 Share Posted January 23, 2014 cant help on the button part numbers... How was the conversion carried out? Check the orange connectors - all the solder joints and take a look at this link http://www.internetwork.org.uk/electrical/dry/flick.htm Having an overlay will not help your situation, but the stock dial backing do have a natural green/yellow tinge on the back. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted January 23, 2014 Author Share Posted January 23, 2014 Thankyou for the link. The conversion was carried out using your very guide. Maybe i will look at changing the dials to a proper set then or trying taking them apart and see if has some sort of filter on the back of the overlay. Quote Link to comment Share on other sites More sharing options...
heckler Posted January 23, 2014 Share Posted January 23, 2014 Thankyou for the link. The conversion was carried out using your very guide. Maybe i will look at changing the dials to a proper set then or trying taking them apart and see if has some sort of filter on the back of the overlay. right, in that case, check the legs of the resistors (top row, far left one) they can touch some of the link wires, if they do, nothing works - just bend the leg slightly away To be honest, you'll be best of replacing the dials. The filter is part of the dials - it can be removed with wet n' dry paper but you'll have to remove the dial faces Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted January 23, 2014 Author Share Posted January 23, 2014 Ok thankyou, this is something im going to do on Saturday so thanks for the quick response, i shall try your sugestions and report back. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted January 25, 2014 Author Share Posted January 25, 2014 Sorted the speedo, however the acunit lights still arnt lighting up as they should any ideas? Quote Link to comment Share on other sites More sharing options...
heckler Posted February 1, 2014 Share Posted February 1, 2014 Did you check the leds? Try plugging in the ac unit without the front on, that way you can see what is going on Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted February 2, 2014 Author Share Posted February 2, 2014 I can do that however, everything is lighting up in the 'dim mode' when the headlights are on its only when the headlights are off I have any issues. I have just bought a multimetere as I was trying to diagnose an alternator issue so guess that could be useful for this problem too Quote Link to comment Share on other sites More sharing options...
