Water circulation noise on accelaration
mobius
Getting this sometimes noise seems to be from bulkhead location, checked coolant level all OK expansion tank on limit rad down a little 5mm from bottom of cap heater works OK and more impotantly carpet at passenger footwell dry. checked when engine cold.
Voice of gloom lets hope airlock will investigate further thanks
Sorry mate but if it happens often when you go full throttle for the first time every drive then, im pritty sure it is as I have had it happen to me for a while before it completely let go,
It could be aif lockif you have changed somthing recently to do with the water system?
