Pete Posted January 21, 2014 Share Posted January 21, 2014 These look interesting. Load up with a free SIM card from O2 or giffgaff http://www.amazon.co.uk/gp/product/B003XDN58K/ref=olp_product_details?ie=UTF8&me=&seller= Anyone tried it? Works from 2G signal which should be OK in most areas. I'm interested in how practical it is to enable it. Is it a button you have to remember or could your alarm arm/disarm I wonder? I found ti via the HotUKDeals thread which has some interesting comments. Link to comment Share on other sites More sharing options...
ScottC Posted January 21, 2014 Share Posted January 21, 2014 Looks just like the one I have fitted from the group buy. Link to comment Share on other sites More sharing options...
imi Posted January 21, 2014 Share Posted January 21, 2014 Pete - a few threads on these on here where some members have them installed and are providing valuable feedback Link to comment Share on other sites More sharing options...
Pete Posted January 21, 2014 Author Share Posted January 21, 2014 Pete - a few threads on these on here where some members have them installed and are providing valuable feedback Ta. I did a quick search on "tracker" and didn't see anything immediately. I'll look again when I have more time. Link to comment Share on other sites More sharing options...
ScottC Posted January 21, 2014 Share Posted January 21, 2014 (edited) They are good for the money. You have to set it up and turn features on and off by sending the unit a text message which is easy enough, and the unit will reply back confirming that that perticllar setting has been set. The problem is the are loads of features so it's hard to remember all the codes. There are apps available like the Back2you app, so for example if you wanted to arm the system you just press arm and it will automatically generate a text with the correct command and password for the device for you to send. It has 3 programmed buttons, Arm, Disarm and Locate Tracker, with only two extra that you can programe with what ever you like. Someone could be on to a winner if they could design a decent app. I have mine set to send a text for the following The toad alarm goes into alarm state The ignition is turned on The car battery is running low The shock sensor has been triggered The battery has been disconnected It leaves the area that the car is parked in when armed You can also set it up to alert you if the car goes over a pre defined mph, handy if you're leaving your car at a garage It has a built in mic, so you can ring the tracker and listen in to what's going on in the car It's also linked to the back2you server and for £10 a year you can have live tracking which also stores all the data HTH Edited January 21, 2014 by ScottC (see edit history) Link to comment Share on other sites More sharing options...
imi Posted January 21, 2014 Share Posted January 21, 2014 Ta. I did a quick search on "tracker" and didn't see anything immediately. I'll look again when I have more time. http://www.mkivsupra.net/vbb/showthread.php?299963-Real-Time-Car-Tracker-Options Link to comment Share on other sites More sharing options...
Mugello Posted January 21, 2014 Share Posted January 21, 2014 (edited) They are good for the money. You have to set it up and turn features on and off by sending the unit a text message which is easy enough, and the unit will reply back confirming that that perticllar setting has been set. The problem is the are loads of features so it's hard to remember all the codes. There are apps available like the Back2you app, so for example if you wanted to arm the system you just press arm and it will automatically generate a text with the correct command and password for the device for you to send. It has 3 programmed buttons, Arm, Disarm and Locate Tracker, with only two extra that you can programe with what ever you like. Someone could be on to a winner if they could design a decent app. I have mine set to send a text for the following The toad alarm goes into alarm state The ignition is turned on The car battery is running low The shock sensor has been triggered The battery has been disconnected It leaves the area that the car is parked in when armed You can also set it up to alert you if the car goes over a pre defined mph, handy if you're leaving your car at a garage It has a built in mic, so you can ring the tracker and listen in to what's going on in the car It's also linked to the back2you server and for £10 a year you can have live tracking which also stores all the data HTH This looks interesting, I will be getting a tracker for the supra very soon (I almost got the group buy one) Is the one you have described above, the exact same one in the link in the first post ? (Just want to make sure) EDIT - It sounds like you only need a sim card and some credit (so it can text you back) and away you go ? Edited January 21, 2014 by Mugello (see edit history) Link to comment Share on other sites More sharing options...
ScottC Posted January 21, 2014 Share Posted January 21, 2014 This looks interesting, I will be getting a tracker for the supra very soon (I almost got the group buy one) Is the one you have described above, the exact same one in the link in the first post ? (Just want to make sure) EDIT - It sounds like you only need a sim card and some credit (so it can text you back) and away you go ? Let's put it this way, it came in the same box, with the same instructions, with a unit that looks exactly the same as the one posted in that link. The only additional item was that the back2you unit came with two Giff Gaff SIM cards and some additional instructions they had obviously added. Now the guy from back2you is saying they are not the same. I would be interested to know if someone buys the Amazon unit if they can get it registered on the back2you live tracking service. Link to comment Share on other sites More sharing options...
imi Posted January 21, 2014 Share Posted January 21, 2014 Now the guy from back2you is saying they are not the same. Obviously - you're questioning his business model or justifying a 500% Margin I would be interested to know if someone buys the Amazon unit if they can get it registered on the back2you live tracking service. I would be super impressed if they had any issues with that / had motions in place to police it ... Link to comment Share on other sites More sharing options...
ScottC Posted January 21, 2014 Share Posted January 21, 2014 Obviously - you're questioning his business model or justifying a 500% Margin I would be super impressed if they had any issues with that / had motions in place to police it ... My guess is that they log the IMEI numbers on the units they buy, until someone try's to activate an Amazon unit (which you have to do over the phone) we won't know. Link to comment Share on other sites More sharing options...
ScottC Posted January 21, 2014 Share Posted January 21, 2014 (edited) Obviously - you're questioning his business model or justifying a 500% Margin Not really, the chap I spoke to is very helpful. He set the tracker up for the live service and explained step by step all the options and features for over half an hour, he couldn't have been more helpful. Plus they are fully guaranteed so any problems and you can just send it back. Despite all the built in features what I really wanted was something I could track Live on a PC or phone if they car was stolen, so personally I think it's worth paying the extra for the access to the back2you server which works really well and good customer service. I would just put money on that it is the same unit. As for margin, it's no different from a lot of aftermarket parts we buy from traders on here, if it comes from China/Japan, it can be found cheaper on eBay. Edited January 21, 2014 by ScottC (see edit history) Link to comment Share on other sites More sharing options...
Mugello Posted January 21, 2014 Share Posted January 21, 2014 GPRS: With a GPRS enabled SIM card, you can monitor real-time movement of your vehicle with the supplied software on your computer. Is this not the live tracking (the amazon unit) ? Link to comment Share on other sites More sharing options...
ScottC Posted January 21, 2014 Share Posted January 21, 2014 (edited) Is this not the live tracking (the amazon unit) ? I'd rather spend an extra £10 and avoid the headaches. There are loads of threads on the interweb with people who have had trouble getting it to work. Why not give it a go, it's only £30? Edited January 21, 2014 by ScottC (see edit history) Link to comment Share on other sites More sharing options...
Mugello Posted January 21, 2014 Share Posted January 21, 2014 If you can get it to work. I'd rather spend an extra £10 and avoid the hassle. Pm me a link to the other one ? Link to comment Share on other sites More sharing options...
ScottC Posted January 21, 2014 Share Posted January 21, 2014 http://back2you.com/store/product_info.cfm?product_id=52 Link to comment Share on other sites More sharing options...
Pete Posted January 22, 2014 Author Share Posted January 22, 2014 EDIT - It sounds like you only need a sim card and some credit (so it can text you back) and away you go ? Yep. Link to comment Share on other sites More sharing options...
