Fitting clear indicators to pre-facelift!
Gretie22
The side one's just pull out and the front one's will require a loom if you want to use the optional sidelight. I had some ebay one's which you can modify the bulb bit to fit but not have the sidelight. On the ebay one's they come with 3 bolt attachments with only two area's they fit, if you remove the side bolt you can findout where the hole for the 3rd bolt needs to be and then drill one to give it more stability.
- - - Updated - - -
There are guides on here too.
