550s or 750s with EMU
Fly
Hi guys I'm looking for some new injectors as I thought I might be pushing the limit of the the 440s and ideally I don't want to limit myself in terms of bhp because I installed small jets.
Anyway I have heard rumblings on many forums that the emu struggles to run any fuel injector over about the 650cc size, now is this correct or mere speculation?
If I were to install the 750s, assuming the emu can run them I wouldn't want anywhere near that power yet but then I don't have to upgrade the injectors later. However I'm running standard ge fuel lines and rail, aeromotive fpr and walbro 255 pump so I might not be set up yet to run jets as big as 750.
My other thought was the buy 550s as they would be happy at the 500bhp mark and not pushing there duly cycle plus assuming the rumblings are true emu could run them and tts run 550s so I don't think I would have any issues in terms of fuel system hardware.
Just looking for a bit of advice thanks chaps and chappesses.
Again seems to be hit and miss even in this thread we are 50/50 as to if the emu can run the 750s . I know berg Ryan around 500bhp on 440s so they can push their limits . But I don't want to thrash them to their limits. Worst case ile gofor the 550s combined with water meth should provide good results but would rather go for 750s and just run them on a lower power setting
I was running 570cc injectors with EMU at about 530BHP, the area where the EMU struggles is actually the injector lag time, and with some injectors it can be a bit of a task to get the idle correct and smooth, a bit of experimentation usually sorts it, but it will not be the expected/recommended lag times.
