Suprakeith Posted January 17, 2014 Share Posted January 17, 2014 I have purchased a alloy rad to replace mine as it was leaking, I have fitted it and bleed the system. Took a while to get it to fit into rubber mounts but now the radiator is sitting to high for the bonnet to close. Was thinking of slicing the top part of rubber down to lower the radiator height, just asking has anyone else done this or have any ideas please Link to comment Share on other sites More sharing options...
Lee P Posted January 17, 2014 Share Posted January 17, 2014 Sounds like one of those Ebay specials with the square top and bottom They don't fit unfortunately and usually you cant bolt the fan shroud on either I think if you look from underneath the rad is fouling on the cross member so cutting the rubbers down probably wont help Link to comment Share on other sites More sharing options...
safcdixon Posted January 17, 2014 Share Posted January 17, 2014 I would send it back, if it dont fit you should get a refund it must be huge to not let the bonnet close i wouldnt trim the rubbers personally as you could end up not giving it enough support and lead to it cracking again Link to comment Share on other sites More sharing options...
Lee P Posted January 17, 2014 Share Posted January 17, 2014 I have purchased a alloy rad to replace mine as it was leaking, I have fitted it and bleed the system. Took a while to get it to fit into rubber mounts but now the radiator is sitting to high for the bonnet to close. Was thinking of slicing the top part of rubber down to lower the radiator height, just asking has anyone else done this or have any ideas please If you do send it back and need one that fits mine are in stock Link to comment Share on other sites More sharing options...
Suprakeith Posted January 17, 2014 Author Share Posted January 17, 2014 If you do send it back and need one that fits mine are in stock How much are your aluminium radiators please? Link to comment Share on other sites More sharing options...
Suprakeith Posted January 17, 2014 Author Share Posted January 17, 2014 Sounds like one of those Ebay specials with the square top and bottom They don't fit unfortunately and usually you cant bolt the fan shroud on either I think if you look from underneath the rad is fouling on the cross member so cutting the rubbers down probably wont help I will look underneath Sunday and see what the rad is catching on, it is one of the eBay specials with the square top and bottom. Need the supra running Monday for work so worst case is put my old leaking radiator back on Link to comment Share on other sites More sharing options...
Shane Posted January 17, 2014 Share Posted January 17, 2014 You can get them to fit but it's bit of a mission. About 10mm sliced off from the rubbers, I used a retractable craft knife to do this, and you also need to lose the top air intake scoop. For me it wasn't an issue as I had already decided to stick my intake in the lower vent but if you want to use the stock airbox then you may have a problem if the rad is the same as the one I have. Also, I picked up a nice rad cap from JAE and when fitted the bonnet didn't sit right until a little sound proofing had been cut out because it was chunkier. If I ever do this again.....here's hoping not, I would probably just pay a bit more and get the ones that Hodge uses or maybe an SRD one, there's a thread on here somewhere about it. Link to comment Share on other sites More sharing options...
Suprakeith Posted January 18, 2014 Author Share Posted January 18, 2014 Well I going to send back the eBay special and get proper radiator that will know will fit, as also can't get my cowling to fit on eBay special. Link to comment Share on other sites More sharing options...
Shane Posted January 18, 2014 Share Posted January 18, 2014 Well I going to send back the eBay special and get proper radiator that will know will fit, as also can't get my cowling to fit on eBay special. Ah I see. Again that wasn't a problem for me as I use electric fans, one 14" and one 12". Link to comment Share on other sites More sharing options...
buster Posted January 18, 2014 Share Posted January 18, 2014 I got a e-bay rad and fits a treat.... Strange Link to comment Share on other sites More sharing options...
Suprakeith Posted January 18, 2014 Author Share Posted January 18, 2014 Think it's just luck of the drawer with eBay one's, have just ordered a SRD rad as I want to keep the cowling on mine, plus the SRD one will fit properly and will be good quality. Have learnt lesson for sure, won't be buying bits for supra from eBay any more,would rather pay the extra and know it's designed for the supra. Link to comment Share on other sites More sharing options...
inazone Posted January 18, 2014 Share Posted January 18, 2014 Only the best for 'sophy' now on then Keith! Link to comment Share on other sites More sharing options...
Suprakeith Posted January 18, 2014 Author Share Posted January 18, 2014 Only the best for 'sophy' now on then Keith! 100% only the best for Sophie now for sure, work too hard to buy low grade products that aren't right. Link to comment Share on other sites More sharing options...
