Hassan Posted January 16, 2014 Share Posted January 16, 2014 Hi im just planning on buying some 295/30/19 tyres. Will these fit my current wheels which are 9.5x19 38et? Plus i think i will need to roll up the rear arches too? Quote Link to comment Share on other sites More sharing options...
listy Posted January 16, 2014 Share Posted January 16, 2014 imo they are too big for a 9.5 rim. Ideally a 9.5 should have between a 255 and 275 tyre iirc. A 295 would be good for a 10.5 rim. Quote Link to comment Share on other sites More sharing options...
listy Posted January 16, 2014 Share Posted January 16, 2014 (edited) Rim width~Minimum tyre width~Ideal tyre width~~~Maximum tyre width 8,5 Inches~~~~225 mm~~~~~235 or 245 mm~~~~~~255 mm 9,0 Inches~~~~235 mm~~~~~245 or 255 mm~~~~~~265 mm 9,5 Inches~~~~245 mm~~~~~255 or 265 mm~~~~~~275 mm 10,0 Inches~~~255 mm~~~~~265 or 275 mm~~~~~~285 mm 10,5 Inches~~~265 mm~~~~~275 or 285 mm~~~~~~295 mm 11,0 Inches~~~275 mm~~~~~285 or 295 mm~~~~~~305 mm 11,5 Inches~~~285 mm~~~~~295 or 305 mm~~~~~~315 mm 12,0 Inches~~~295 mm~~~~~305 or 315 mm~~~~~~325 mm 12,5 Inches~~~305 mm~~~~~315 or 325 mm~~~~~~335 mm Edited January 16, 2014 by listy (see edit history) Quote Link to comment Share on other sites More sharing options...
Hassan Posted January 16, 2014 Author Share Posted January 16, 2014 I spoke with my alloy wheel shop and he said to me yes they will fit. Now ive promiced to meet someone in the morning to buy these tyres Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted January 16, 2014 Share Posted January 16, 2014 They will fit, But wont sit flush with the rim I doubt it. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted January 16, 2014 Share Posted January 16, 2014 they will go on fine. a bit of over hang will give you good rim protection Quote Link to comment Share on other sites More sharing options...
listy Posted January 16, 2014 Share Posted January 16, 2014 I used to have 11" rears on a 295 with a very aggressive arch roll and arch pull. 295 will probably fit, but they aren't recommended. Quote Link to comment Share on other sites More sharing options...
Nic Posted January 16, 2014 Share Posted January 16, 2014 275/35R19 or 265/35R19 would suit your wheel widths better. Quote Link to comment Share on other sites More sharing options...
Hassan Posted January 17, 2014 Author Share Posted January 17, 2014 As long as they fit for now then thats cool. Since come march im going to be getting new wheels. Thanks everyone. Quote Link to comment Share on other sites More sharing options...
Gpro Posted January 17, 2014 Share Posted January 17, 2014 They will definitely fit, The table posted above is a approximate guideline. Depending on rim size (17"/18"/19") makes a difference. Quote Link to comment Share on other sites More sharing options...
Hassan Posted January 18, 2014 Author Share Posted January 18, 2014 (edited) They do fit but got a slight rub. Im getting the arches rolled monday morning. Do you guys think With my 38et, 9.5 wide and 295 tyre will i be able to use a 10mm wheels spacer? Edited January 18, 2014 by Hassan (see edit history) Quote Link to comment Share on other sites More sharing options...
listy Posted January 18, 2014 Share Posted January 18, 2014 Hassan said: They do fit but got a slight rub. Im getting the arches rolled monday morning. Do you guys think With my 38et, 9.5 wide and 295 tyre will i be able to use a 10mm wheels spacer? If it rubs as it is, then even with an arch roll, I doubt it. Maybe with an aggressive arch pull like I have, but not with just a roll I don't think. Quote Link to comment Share on other sites More sharing options...
Hassan Posted January 18, 2014 Author Share Posted January 18, 2014 With just arch roll ive had 305/25/20 with 10j wheel on my last supra. With no rub. Quote Link to comment Share on other sites More sharing options...
