Tsia Posted January 15, 2014 Share Posted January 15, 2014 Hi guys, Recently acquired a new Supra that has hybrid twins on it, with an MBC set to 0.9 bar. I'll be fitting my Blitz DSBC soon to poke the boost up a little, as it simply feels lethargic at that level. I've had a little search around but can't seem to find what people believe to be a safe area to up the boost to with 440s & hybrids? Cheers Link to comment Share on other sites More sharing options...
drift_bear Posted January 15, 2014 Share Posted January 15, 2014 I ran 1.5bar on 550cc injectors HTH Link to comment Share on other sites More sharing options...
jimojameso Posted January 15, 2014 Share Posted January 15, 2014 I ran 1.2bar on mine with 440s Link to comment Share on other sites More sharing options...
DodgyRog Posted January 15, 2014 Share Posted January 15, 2014 From what I have gathered, 1.2 bar is pushing the 440 injectors quite a bit I sure I have seen that it's not good to push them to 100% either 1.2 bar is seen as the max of the ceramic turbos as well Link to comment Share on other sites More sharing options...
Tsia Posted January 15, 2014 Author Share Posted January 15, 2014 Hmm, looks like I'll need bigger injectors sooner than I thought. 0.9 bar is pretty awful (I can only presume because larger turbines + nearly stock boost = pointless?), so I can't see 1.2 bar giving me quite enough power to be satisfied with it. Cheers guys. Link to comment Share on other sites More sharing options...
Graham1984 Posted January 15, 2014 Share Posted January 15, 2014 Hmm, looks like I'll need bigger injectors sooner than I thought. 0.9 bar is pretty awful (I can only presume because larger turbines + nearly stock boost = pointless?), so I can't see 1.2 bar giving me quite enough power to be satisfied with it. Cheers guys. Would you like some sympathetic words from someone who thinks boost is just a chocolate bar? Link to comment Share on other sites More sharing options...
Nic Posted January 15, 2014 Share Posted January 15, 2014 (edited) It depends on the spec of the hybrid turbos, if they flow significantly more air than the stock turbos then you could be in danger of running lean above 1bar. Putting the car on a dyno will tell you just how much boost is safe to run with the 440cc injectors Edited January 15, 2014 by Nic (see edit history) Link to comment Share on other sites More sharing options...
tooquicktostop Posted January 15, 2014 Share Posted January 15, 2014 Are you sure they are Hybrid, seems odd to fit them and not have the rest of the set up changed to make the most of them? 1.2 bar is maxing out the 440's, bit risky if you ask me I ran 1.25 bar on 550 injectors Link to comment Share on other sites More sharing options...
Tsia Posted January 15, 2014 Author Share Posted January 15, 2014 Yeah, they definitely don't spool like my old stock turbos nor make the same sound at all (not to mention the car has been on this club for circa 10 years, can see all the history!) Well, looks like this is going to be expensive Link to comment Share on other sites More sharing options...
drift_bear Posted January 15, 2014 Share Posted January 15, 2014 Is this the 1A1 supra that was up for sale? Link to comment Share on other sites More sharing options...
Tsia Posted January 15, 2014 Author Share Posted January 15, 2014 It is. Link to comment Share on other sites More sharing options...
thetrashcanman Posted January 15, 2014 Share Posted January 15, 2014 Get it Dyno'd 400bhp is the limit on the 440cc injectors otherwise you will be melting things Link to comment Share on other sites More sharing options...
Tsia Posted January 15, 2014 Author Share Posted January 15, 2014 It's nowhere near that at the moment, so I think I'm pretty safe (for now!) Link to comment Share on other sites More sharing options...
Justin Bieber Posted January 15, 2014 Share Posted January 15, 2014 Get it Dyno'd 400bhp is the limit on the 440cc injectors otherwise you will be melting things Is it the limit?? Link to comment Share on other sites More sharing options...
