Tyre size
mac79
Whats the reason for the deeper tyre on the front?
If you use the tyre calculator posted a bit further up it calculates on the % of width & diameter change. The larger size wall on the front with a smaller width than the rears. It is also the closest to stock setup for an 18" wheel.
? It's not got a larger sidewall, Alex explained earlier, the 35 or 40 is a percentage of the tyre width. 40% of 235mm gives a 94mm sidewall, 35% of 265mm gives a 92.75mm one. I'd not class that as "deeper" :)
