Crash Bandicoot Posted January 12, 2014 Share Posted January 12, 2014 Hi, after some advice on the cruise control... On my build, I've moved across my NA-t lump from from my 5 speed NA to my aerotop. The 5 speed was an m reg and has been manual all its life. The aerotop started life as an auto, before I had it off Keron it had a TT lump in, now it has my 5 speed NA-t lump in. The aerotop has a cruise control box in... How would I go about getting this working? Where do the controls go? Steering wheel? Dash? I can't see any controls for it Any advice/help is appreciated Quote Link to comment Share on other sites More sharing options...
ScottC Posted January 12, 2014 Share Posted January 12, 2014 (edited) You'll need a steering wheel with a cruise control stalk, ecu, 4 pin brake pedal switch and a cruise control motor. Edit. If you already have the ecu fitted the likly hood is you will have the 4 pin brake pedal switch Edited January 12, 2014 by ScottC (see edit history) Quote Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted January 13, 2014 Author Share Posted January 13, 2014 Oh, are the steering wheels with cruise control I'm going to trace the cruise control wiring back to see what I have got. Quote Link to comment Share on other sites More sharing options...
ScottC Posted January 13, 2014 Share Posted January 13, 2014 Cruise control is fitted to the steering wheel if that's what you mean. There should be a plug in the engine bay for the motor and a white plug inside your steering wheel for the cruise control stalk to plug into. If you have those plugs then you are good to go. Quote Link to comment Share on other sites More sharing options...
