scott87 Posted January 12, 2014 Share Posted January 12, 2014 I am considering buying a tt sump rather than drilling mine, but am still left with the issue of needing assistance changing the sumps over as i dont have a drive, i'd imagine we could do the work on my road as it is far less of a job than drilling the sump however. Basically looking for someone to come and lend a hand, bring some spare tools, i do have quite a few. Also got jacks, axle stands, old-school metal drive on ramp things. Anyone that could help that would be great. Looking to do the work asap as i need to get an na part off my car and posted out to another member. Thanks Quote Link to comment Share on other sites More sharing options...
GMan Posted January 12, 2014 Share Posted January 12, 2014 (edited) don't you have to drop the front subframe to change the sump? Seems a bit much to do on a road on jackstands. The police in Germany would fine you heavily if you tried it on a public road here. I'm assuming UK is a bit more Forgiving about it? Edited January 12, 2014 by GMan (see edit history) Quote Link to comment Share on other sites More sharing options...
listy Posted January 12, 2014 Share Posted January 12, 2014 Do you realise how much of a job it is to change the upper sump? The whole sub frame needs to be dropped to get it off and out. It's a pretty big job. I wouldn't fancy doing it on the road. I've done it twice now, but had it on a 4 post ramp. I couldn't imagine doing it on stands. It would be a right pita. Personally, I'd try and get it on a proper ramp. Drilling the sump in situe would probably be easier. Quote Link to comment Share on other sites More sharing options...
scott87 Posted January 12, 2014 Author Share Posted January 12, 2014 Do you realise how much of a job it is to change the upper sump? The whole sub frame needs to be dropped to get it off and out. It's a pretty big job. I wouldn't fancy doing it on the road. I've done it twice now, but had it on a 4 post ramp. I couldn't imagine doing it on stands. It would be a right pita. Personally, I'd try and get it on a proper ramp. Drilling the sump in situe would probably be easier. Ive been told by a few people that the subframe just needs to be loostened and then the sump can be 'slid' out. If this is not the case i will revert to my original plane of having the sump i have drilled. Quote Link to comment Share on other sites More sharing options...
jason a Posted January 12, 2014 Share Posted January 12, 2014 looking forward to the updates Quote Link to comment Share on other sites More sharing options...
