Can paint be removed from carbon fibre?
Al Massey
Guest pwings18
Possible to do this.
But very careful with sanding.
Other solution : hope sanding before painting was not very good.
So you can use air to remove paint.
Or Karcher in a third solution.
I can do this but trip to France may cost a few money ! :D
Edited by pwings18 (see edit history)
Cheers for the replies.
Carbon Fibre can be de-lacquered and re-lacquered when it goes cloudy, so I imagine it would be the same kind of process.
I'd just be VERY careful who you choose to do it.
I thought as much.
I will be very careful, was hoping someone here has had it done.
It's just a case of flatting off the paint slowly then re lacquer it can be done don't know of any garages though
Oh and congrats on buying an awesome car mate
Cheers dude :)
Congrats of the purchase.
Below is a thread from a member on the evo forum explaining the process. Hope it helps :)
http://m.evolutionm.net/showthread.php?t=530494&styleid=27
Cheers mate :)
Thanks for the link, may be hard doing that as I'm planning on just having the vents carbon on show.
Ha ha, yeah a bit expensive lol
I would stay away from heavy grit paper and 2000 grit it down with a bucket of water and a block, time consuming but that's probs the best way of not damaging the carbon weave. It will be a way slower process but atleast you can keep an eye on how far your taking it down. That's how I would do it anyway.
Jet wash is my number one way but then it depends on the quality of the carbon Bonet itself, if it's crap you will blast straight through it.
Check the underside of the bonnet and if it's fiber glass than the quality will be crap.
If it's carbon then blast away as it will be proper stuff.
Oooooo pics of the car I've searched for TRD rob and can't find anything
It's genuine carbon fibre throughout.
Here's the for sale thread
TRD3000gt-single-6-speed-Aerotop
http://www.mkivsupra.net/vbb/showthread.php?t=291007
Guest pwings18
Jet wash... I do this on every piece I have to respray. To see if old paint was well done or not.
Especially on alloy wheels or plastic.
p500 on a dual action sander with a soft backing pad will be fine to then re laquer, maybe p800 wet n dry round the edges and in the corners of the vents, anything finer than that n you will be at it for a month of sundays
if you start trying solvents to wash it off you will get in a right mess
