shaz2010 Posted January 10, 2014 Share Posted January 10, 2014 Hi all does anyone no if the discs on my supra should have slight play, as in when the wheel is off and moving the disc it shifts left and right slightly hitting the hub studs ! When I installed my new discs I noticed there was no holes in the hub to screw the disc to it? I've had a knock only while reversing and on half a lock,which is the same noise as what I'm explaining about. Cheers lads & lasses. Link to comment Share on other sites More sharing options...
David P Posted January 10, 2014 Share Posted January 10, 2014 It's the wheel & nuts that locate the disc. Link to comment Share on other sites More sharing options...
shaz2010 Posted January 10, 2014 Author Share Posted January 10, 2014 It's the wheel & nuts that locate the disc. Yes David is that normal mate ? Or is there a fix Link to comment Share on other sites More sharing options...
David P Posted January 10, 2014 Share Posted January 10, 2014 Quite normal. Link to comment Share on other sites More sharing options...
shaz2010 Posted January 10, 2014 Author Share Posted January 10, 2014 Quite normal. Cheers it's funny because the discs have got tapped holes where it could be screwed into the hub. And they are genuine uk spec discs from Toyota. Link to comment Share on other sites More sharing options...
Kirk Posted January 10, 2014 Share Posted January 10, 2014 They're there to help remove the disc from the hub should it become stuck on through corrosion. Link to comment Share on other sites More sharing options...
Guest Roger NE Posted January 10, 2014 Share Posted January 10, 2014 They're there to help remove the disc from the hub should it become stuck on through corrosion Yes I sussed that out myself a few years ago when I couldn't get one of the old discs off a car . . . tried hitting it with a hammer, but wouldn't free up . . . Then I thought "Maybe that's what those tapped holes are for?" . . screwed a bolt into the hole . . then CRACK - it broke the rusty bond between the disc and the hub ! Link to comment Share on other sites More sharing options...
shaz2010 Posted January 10, 2014 Author Share Posted January 10, 2014 Ah that's what they are for nice one ta. Didn't experience that the just dropped off with a little hit with a rubber mallet . Cheers for the info lads Link to comment Share on other sites More sharing options...
trebor69 Posted January 10, 2014 Share Posted January 10, 2014 Stripped the threads in the holes on mine trying to pry it off......no joy, is mega stuck, good job its got loads of meat and not warped.....will heat it up when I come round to changing it Link to comment Share on other sites More sharing options...
