Noz Posted January 9, 2014 Share Posted January 9, 2014 Can't find a huge amount of information on this. Even outside the forum. I've seen discussion on various issues, but never seen anywhere that collated information has been listed for benefits of setups against each other. I've currently got a walbro 255, and looking to upgrade. At this time I'm unsure where I'm heading, so for now just doing research on my current setup. Just thought it would be useful to have a thread relating directly to the benefits of each, IF there even is any. Also, would an improved pressure regulator be recommended with the increase in flow to the rail. Link to comment Share on other sites More sharing options...
Noz Posted January 9, 2014 Author Share Posted January 9, 2014 Found this: http://realstreetperformance.com/store/pages/fuel-pump-comparison-test-5.html Good comparison of single pumps Link to comment Share on other sites More sharing options...
mellonman Posted January 9, 2014 Share Posted January 9, 2014 why pay for two when you can do it with one , statisticly two have twice the amount of failure but you may not pick it up until high boost and by then its too late my 255 run my 524 bhp okay on the limit but still good, then i went for the walbro lp400 slightly bigger fits perfictly in the hanger and delivers alot more fule great pump Link to comment Share on other sites More sharing options...
Chris Bailey Posted January 9, 2014 Share Posted January 9, 2014 Walbro 450! Link to comment Share on other sites More sharing options...
chazuk Posted January 9, 2014 Share Posted January 9, 2014 Bosch 044 in tank Link to comment Share on other sites More sharing options...
LOGIE Posted January 9, 2014 Share Posted January 9, 2014 Bosch 044 in tank This. Is what I'll be getting soon. Link to comment Share on other sites More sharing options...
Nodalmighty Posted January 9, 2014 Share Posted January 9, 2014 (edited) My money is on a Walbro 450. It's quieter than a 044 and in some areas of the graph it's better. Lyndon. Edited January 9, 2014 by Nodalmighty (see edit history) Link to comment Share on other sites More sharing options...
Alex Posted January 9, 2014 Share Posted January 9, 2014 The benefit of Single Pumps is simply that you are less likely to suffer unexpected detonation because if the pump dies the car doesn't run. With 2 pumps you can still run, and then unbeknown to you the second pump has failed and doesn't supply the extra fuel when demanded at high rpm/boost. You go lean & detonate...unless you have some very sophisticated fail safes. Link to comment Share on other sites More sharing options...
Fly Posted January 9, 2014 Share Posted January 9, 2014 What about using the stock with the 255? Saves having to buy a new pump assuming the original works well but i suppose that's a bit budget. Link to comment Share on other sites More sharing options...
mellonman Posted January 9, 2014 Share Posted January 9, 2014 What about using the stock with the 255? Saves having to buy a new pump assuming the original works well but i suppose that's a bit budget. but that would still be 2 pumps one new and one thats 20 years old , i cant even think of a worse combination edit: 2x 20 year old pumps Link to comment Share on other sites More sharing options...
imi Posted January 9, 2014 Share Posted January 9, 2014 What about using the stock with the 255? Saves having to buy a new pump assuming the original works well but i suppose that's a bit budget. what sort of power are you pushing and what are the flow requirements for the setup? If its anything less than 600bhp then its a pointless thread. imi Link to comment Share on other sites More sharing options...
Alex Posted January 9, 2014 Share Posted January 9, 2014 You need to be running serious power to need more than a single 255Walbro. Link to comment Share on other sites More sharing options...
hodge Posted January 9, 2014 Share Posted January 9, 2014 Single Bosch 044 in tank is all you'll ever need unless you want over 800hp Link to comment Share on other sites More sharing options...
JamieP Posted January 9, 2014 Share Posted January 9, 2014 As hodge says, 044 FTW. Link to comment Share on other sites More sharing options...
Guest Budz86 Posted January 9, 2014 Share Posted January 9, 2014 I tend to think of fuel pumps like injectors; the lower duty you run them at, the better. 044's may be expensive, but they will be more than enough for 90% of builds. I'm only BPU++ but will be chucking in a 044 when I overhaul the rest of the fuel system (I've only done injectors so far). Noz, with regards to your original question, I'm not sure what the benefits or more than one pump are, but I'm assuming it's something along the lines of 'lower duty, more longevity'. Also, if running something like a Syvecs that can detect a drop in fuel pressure, if one pump dies, the ECU can go into limp mode and prevent a total loss of fuel (instead of the engine just cutting out completely) which could be extremely dangerous depending on the situation you are in at the time! Link to comment Share on other sites More sharing options...
Luxluc Posted January 9, 2014 Share Posted January 9, 2014 Single Bosch 044 in tank is all you'll ever need unless you want over 800hp +1 I will replace my twin Walbro by twin 044. In case of a twin setup, you normally run 1 of the 2 pumps and the second one kicks in if needed. Link to comment Share on other sites More sharing options...
Mgrene Posted January 9, 2014 Share Posted January 9, 2014 +1 I will replace my twin Walbro by twin 044. In case of a twin setup, you normally run 1 of the 2 pumps and the second one kicks in if needed. Please correct me if I'm wrong but that depends on how you do your twin setup (Parallel or series set-up) Link to comment Share on other sites More sharing options...
Guest Budz86 Posted January 9, 2014 Share Posted January 9, 2014 Please correct me if I'm wrong but that depends on how you do your twin setup (Parallel or series set-up) Correct, but this seems the logical way to set them up when you need large amounts of fuel Link to comment Share on other sites More sharing options...
listy Posted January 9, 2014 Share Posted January 9, 2014 Single Bosch 044 in tank is all you'll ever need unless you want over 800hp I've been talking to Noz.......... Link to comment Share on other sites More sharing options...
ashbuster Posted January 10, 2014 Share Posted January 10, 2014 im fitting the walbro 450 in mine too Link to comment Share on other sites More sharing options...
Noz Posted January 10, 2014 Author Share Posted January 10, 2014 My target power value is all dependent itself on the components required. I would rather set a budget value and modify depending on what I'm willing to spend than set a bhp target. Thus carrying out research and component investigation to give me an idea of whats possible and within easy reach. Realistically, I want a few changes within my Ultimate Emanages capabilities. I'm not going for a target bhp until I've changed ECU's at least. From what I've read, the Bosch 044 will be what I'm looking for at this time. I was also interested in the pump selection on comparison of single vs twin. There doesn't seem a difference from peoples experience, just depends on what the user selects by the look of things. Perhaps introducing a smaller pump would help an over heating pump working close to its limit would be a prevention measure, rather than a direct benefit (i.e. OEM pump). I think it's safer to run with a single pump for now. Link to comment Share on other sites More sharing options...
mellonman Posted January 10, 2014 Share Posted January 10, 2014 from what i can gather , the pumps will always run at full chat unless modified , ie the fuel ecu in the rear panel 9v idle and then 12 with any boost , this was done to stop the fuel heating in the tank , adding 2 or 3 pumps vs 1 larger pump , i gues the smaller pumps may not get as hot but may have some more surface area , best way to test maybe get some old stockers and the bosch 044 put them each in a bucket with water and a 12v feed for 20minutes and see how hot they get or the actual water gets how hot each pump gets would depend on windings and friction Link to comment Share on other sites More sharing options...
Luxluc Posted January 10, 2014 Share Posted January 10, 2014 Please correct me if I'm wrong but that depends on how you do your twin setup (Parallel or series set-up) Normally, you run them in serie. Only if you run massive power and that one isn't enough, you need to run them in parallel. Link to comment Share on other sites More sharing options...
Luxluc Posted January 10, 2014 Share Posted January 10, 2014 My target power value is all dependent itself on the components required. I would rather set a budget value and modify depending on what I'm willing to spend than set a bhp target. Thus carrying out research and component investigation to give me an idea of whats possible and within easy reach. Realistically, I want a few changes within my Ultimate Emanages capabilities. I'm not going for a target bhp until I've changed ECU's at least. From what I've read, the Bosch 044 will be what I'm looking for at this time. I was also interested in the pump selection on comparison of single vs twin. There doesn't seem a difference from peoples experience, just depends on what the user selects by the look of things. Perhaps introducing a smaller pump would help an over heating pump working close to its limit would be a prevention measure, rather than a direct benefit (i.e. OEM pump). I think it's safer to run with a single pump for now. Go for a Bosch 044 pump mate. You can run these for 700-750 bhp without a problem. They are very good. Link to comment Share on other sites More sharing options...
Noz Posted January 10, 2014 Author Share Posted January 10, 2014 044 fit in the OEM hanger? Link to comment Share on other sites More sharing options...
