Moo's - Widebody Aerotop Turbo Manual - Build Thread - CCW's !
Mugello
UPDATE:
With my time being split to weekdays at university and weekends at home, i tend to spend most of my time away from the supra :(
However, i always try to find things to do at university that will progress the build without being at home :eyebrows:
So, using the template on the forum i cut two of these out in the workshop at university....
As much as i love working hands on, i did not fancy cutting the rings out by hand (Plus the laser ensures a perfect circle)
Ended up with this...
Then all glued with a strong MDF glue and i put some small screws in from the back for extra strength :)
Then i uploaded my next CAD file to the laser cutter :eyebrows:
Its my own custom jig to measure the clearance needed to clear the 8pot/6pot setup (the spacers which are different thicknesses and the oval shape) and the long thin length showing the rim widths.
Anyone want to guess who is making these wheels ? :cool:
(James you cant play :D )
Is making?? or have made?
I can only guess you're making your own wheels?
Having made ;)
I wish i could make wheels !
Was it those Wide Ass wheels that James bought for the car then sold on after he bought the Green Car?
Nope. I did like them though and probably should of bought them tbh !
I was dealing with a guy called 'Jonathon' if that helps ;)
Having made ;)
Its possible with some black paper, a bit of glue and an oven :D
Having made ;)
Some CCWs by any chance?
  • 3 weeks later...
Looks like my first year (of 2) for my masters is over :)
That means time for updates....
While at university these arrives which i began to split as the chrome was flaking off insider on the rings, they also had a tint film on the outside
http://mkivsupra.net/vbb/attachment.php?attachmentid=186474&stc=1&d=1401474800
http://mkivsupra.net/vbb/attachment.php?attachmentid=186475&stc=1&d=1401474800
With the tint film off it was time to use the oven :p
http://mkivsupra.net/vbb/attachment.php?attachmentid=186476&stc=1&d=1401474800
And the flaking chrome....
http://mkivsupra.net/vbb/attachment.php?attachmentid=186477&stc=1&d=1401474800
Naturally, being male i was not the best at the oven part and managed to melt one lens :taped:
So if anyone has a matching pair drop me a pm :thumbs:
Next was a trip home at the weekend to fit the speaker mounts i had made.
Although i used very strong wood glue, for a bit of strength i put a couple small screws in back of them
http://mkivsupra.net/vbb/attachment.php?attachmentid=186482&stc=1&d=1401475095
And in keeping with my OCD i used all new stainless steel nuts/bolts to install them :)
http://mkivsupra.net/vbb/attachment.php?attachmentid=186483&stc=1&d=1401475095
I also tidied up/clean the door card plastic membrane etc... But forgot to get a photo :(
Then this arrived from Keron :thumbs: (Great service as always)
Lovely set on manual clocks
http://mkivsupra.net/vbb/attachment.php?attachmentid=186484&stc=1&d=1401475277
With the speaker mounts fitted (still need to sort out what speaker setup i want to install) I decided to install the door cards anyway to stop them getting damaged in storage and because i wanted to see her come together :cool:
So door cards on and cleaned/polished up
http://mkivsupra.net/vbb/attachment.php?attachmentid=186485&stc=1&d=1401475401
Installed most of the dash panels too
It was then i noticed on the passenger side that the dash lines didn't quite line up to the door card lines (hard to see in the below photo) so after some investigation i noticed the dash was a little lose on that side
http://mkivsupra.net/vbb/attachment.php?attachmentid=186486&stc=1&d=1401475401
So out came the two glove boxes
http://mkivsupra.net/vbb/attachment.php?attachmentid=186487&stc=1&d=1401475401
It was just a lose bolt that holds the top part of the dash in, so simple fix.
http://mkivsupra.net/vbb/attachment.php?attachmentid=186488&stc=1&d=1401475401
And all back together, with my OCD happy again :)
http://mkivsupra.net/vbb/attachment.php?attachmentid=186489&stc=1&d=1401475401
Then this arrived from the Ultra Racing group buy, i cant see it adding much strength or much in the way of being stiffer, but the stock brace was rusting so it had to go
http://mkivsupra.net/vbb/attachment.php?attachmentid=186490&stc=1&d=1401475883
And installed with new stainless steel nuts/bolts :)
(Fuel and brake lines to be installed properly once the mid section is undersealed)
http://mkivsupra.net/vbb/attachment.php?attachmentid=186491&stc=1&d=1401475883
More to come soon !
:wave:
Rubbish picture, but shows the strut brace ends being sprayed the same Black 202 as the car :)
They came out very well indeed. Better picture to follow
http://mkivsupra.net/vbb/attachment.php?attachmentid=186692&stc=1&d=1401897219
Next came the custom subframes for the front seats...
http://mkivsupra.net/vbb/attachment.php?attachmentid=186693&stc=1&d=1401897219
And the two Corbeau Pro Series Bucket Seats (Standard Width not XL)
http://mkivsupra.net/vbb/attachment.php?attachmentid=186694&stc=1&d=1401897219
Lovely shiny black backs...
http://mkivsupra.net/vbb/attachment.php?attachmentid=186695&stc=1&d=1401897219
http://mkivsupra.net/vbb/attachment.php?attachmentid=186696&stc=1&d=1401897219
More to come soon :wave:
UPDATE:
Now the rear spoiler is back from the bodyshop and has been fitted, I installed the 3rd center brake light and fitted the interior trim...
http://mkivsupra.net/vbb/attachment.php?attachmentid=186943&stc=1&d=1402340828
http://mkivsupra.net/vbb/attachment.php?attachmentid=186944&stc=1&d=1402340828
The strut brace ends were shot-blasted and resprayed in 202 black. The center bar was wet sanded and polished. It was then all assembled and installed :)
http://mkivsupra.net/vbb/attachment.php?attachmentid=186945&stc=1&d=1402340828
http://mkivsupra.net/vbb/attachment.php?attachmentid=186946&stc=1&d=1402340828
The fuse box will be staying where it is, however the battery will be moving into the boot and fixed down in a custom battery tray.
  • 2 weeks later...
Apologies for the slow progress/updates...
Next was installing the Corbeau Pro-Series Seats (Both FIA approved and in date)
http://mkivsupra.net/vbb/attachment.php?attachmentid=187406&stc=1&d=1403526774
Passenger Side.
http://mkivsupra.net/vbb/attachment.php?attachmentid=187407&stc=1&d=1403526774
Drivers Side.
http://mkivsupra.net/vbb/attachment.php?attachmentid=187408&stc=1&d=1403526774
And a view from the boot
http://mkivsupra.net/vbb/attachment.php?attachmentid=187409&stc=1&d=1403526774
More to come soon !
Moo.
UPDATE:
With the front end coming on nicely, it was time to put the front wings back on.
But not before a lick of underbody sealer to the inside (Being very careful not to scratch the paintwork)
http://mkivsupra.net/vbb/attachment.php?attachmentid=187537&stc=1&d=1403785235
Before and after...
http://mkivsupra.net/vbb/attachment.php?attachmentid=187538&stc=1&d=1403785235
http://mkivsupra.net/vbb/attachment.php?attachmentid=187539&stc=1&d=1403785235
And finished!
Stay tuned, wheel update coming now :taped:
