Guest dlwarrior Posted January 6, 2014 Share Posted January 6, 2014 Supra 3.0 NA Car was taken out of garage for a little run and 2 red lights stay on... When handbrake applied and released lights go out..... now lights staying on??? Can anyone help poss switch for handbrake but not sure.. Thanks Darren Quote Link to comment Share on other sites More sharing options...
Nic Posted January 6, 2014 Share Posted January 6, 2014 Check brake fluid level first, sensor is very sensitive so make sure it is topped just above max limit. If the level is low also check brake pad wear and check for brake fluid leaks. Quote Link to comment Share on other sites More sharing options...
Cipriani Posted January 6, 2014 Share Posted January 6, 2014 What Nic said! Just had the same Quote Link to comment Share on other sites More sharing options...
