brake pad replacement
pauldoug
its not too dark mate, I'm off out to work on my brakes right now ;) come on, you can do it! :)
yep its a 14mm, slackened off mine on sat and re-nipped ready for removal tonight if all goes to plan.
also when I did my research I came across the above threads mentioned- I have a vacuum kit on its way too, should make the job nice and easy to do alone :)
lol, I don't wanna screw anything up so will have to wait for some daylight, cant be too careful when it comes to working on your brakes.
was off to b and q to get a spanner set above 14mm so I could get the carrier off, as I left the street the exhaust mount snapped on my mrs a class :-( job abandoned until her car is sorted lol To keep to the subject, both calipers came off fine, the sliding pins aren't budging so will try and free them off before removing the carriers then I get the chance.
Edited by pauldoug (see edit history)
