teddan Posted January 4, 2014 Share Posted January 4, 2014 (edited) I am planning to take my engine to the next stage and let the turbo do some work. I am running JamieP old turbo a Precision GT42-7675R. When he was running it, he made around 1100 at the hubs I will be running the Cp pistons and they should be fine I think. 1. I talked to trevor at real street and he recommend Manley Turbo Tuff I-Beam Rods with ARP625+ and his advice was not to use a H beam at all. 2. As I am for the moment running BC sportman rods with the ARP2000 I also asked Dustin at BC for advice. But for 1300rwhp he suggest not tu use a steel rod at all.(even though the BC625+ are spec up to 300hp per rod(1800hp on the crank for all 6) 3. Jamie P used a Brian Crower Pro Series Rods. So that are proven! I will run on e85(ethanol) Which rods should I use? Edited January 5, 2014 by teddan (see edit history) Quote Link to comment Share on other sites More sharing options...
teddan Posted January 5, 2014 Author Share Posted January 5, 2014 I think I will go what Jamie used if no ides pop's up Quote Link to comment Share on other sites More sharing options...
Luxluc Posted January 5, 2014 Share Posted January 5, 2014 I went for Carillo HD rods mate. They are the best you can get for the 2JZ engine. They are rated 1600+bhp....so I thought they would he fine for my little 800-900 bhp Quote Link to comment Share on other sites More sharing options...
Luxluc Posted January 5, 2014 Share Posted January 5, 2014 P.S. Jamie pushed 975 rhhp ( at the hubs)on the 7675 turbo....no 1300 at the wheels. Quote Link to comment Share on other sites More sharing options...
teddan Posted January 5, 2014 Author Share Posted January 5, 2014 gahaaaa wrong by me!.....1132 at the hubs:) was the info from jamie P. I corrected it in the first post Thanks for the input Luxluc! Quote Link to comment Share on other sites More sharing options...
V8KILR Posted January 6, 2014 Share Posted January 6, 2014 (edited) Change to the ARP625+ rod bolts with your BC Sportman rods and you will be fine as that's then the same as the Brian Crower Pro Series Rods. The piston wrist pins are even more important as the stock CP pins are not strong enough, so make sure you upgrade yours to the CP PRO PIN 2.250. Are you still running stock main caps? If so then 1100whp is getting to the level where you should be thinking of billet main caps as well. I currently run the Brian Crower Pro Series Rods and I will be doing the CP PRO PIN 2.250 and billet main caps this year in a new twin 61mm (equivalent to an 86mm single) turbo setup. Edited January 6, 2014 by V8KILR (see edit history) Quote Link to comment Share on other sites More sharing options...
Lee P Posted January 6, 2014 Share Posted January 6, 2014 BC pro rods would be fine, same as we use in all the big power builds. Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted January 6, 2014 Share Posted January 6, 2014 Arrow rods. Lyndon. Quote Link to comment Share on other sites More sharing options...
teddan Posted January 6, 2014 Author Share Posted January 6, 2014 (edited) Change to the ARP625+ rod bolts with your BC Sportman rods and you will be fine as that's then the same as the Brian Crower Pro Series Rods. The piston wrist pins are even more important as the stock CP pins are not strong enough, so make sure you upgrade yours to the CP PRO PIN 2.250. Are you still running stock main caps? If so then 1100whp is getting to the level where you should be thinking of billet main caps as well. I currently run the Brian Crower Pro Series Rods and I will be doing the CP PRO PIN 2.250 and billet main caps this year in a new twin 61mm (equivalent to an 86mm single) turbo setup. According to trevor at real street is is not possible to change arp bolts but when I look at BC homepage it looks like it should work. Have you any experience to of the sportman rods? What they will handle after change bolts? as I read it the should be the same spec as BC 625 rods Thanks for the input of the pins! I will order that. I have not heard about before! great! I will change to billet main caps, but when I was on the mpv website this morning and then the MVP Motorsports Engine Girdle pop up, has anyone tried that? Edited January 6, 2014 by teddan (see edit history) Quote Link to comment Share on other sites More sharing options...
V8KILR Posted January 6, 2014 Share Posted January 6, 2014 (edited) According to trevor at real street is is not possible to change arp bolts but when I look at BC homepage it looks like it should work. Have you any experience to of the sportman rods? What they will handle after change bolts? as I read it the should be the same spec as BC 625 rods Thanks for the input of the pins! I will order that. I have not heard about before! great! I will change to billet main caps, but when I was on the mpv website this morning and then the MVP Motorsports Engine Girdle pop up, has anyone tried that? Based on the website, the rods are identical and it only the rod bolts that are different. They sell the ARP625+ rod bolts separately now which they didn't used to either. I read up a lot on it but there is no proof that it is of any benefit that I could find. For most girdles, you machine the tops of the main caps flat so the girdle provides support to the center of the caps as well, which the MVP one does not. Edited January 6, 2014 by V8KILR (see edit history) Quote Link to comment Share on other sites More sharing options...
teddan Posted January 6, 2014 Author Share Posted January 6, 2014 (edited) Based on the website, the rods are identical and it only the rod bolts that are different. They sell the ARP625+ rod bolts separately now which they didn't used to either. I read up a lot on it but there is no proof that it is of any benefit that I could find. For most girdles, you machine the tops of the main caps flat so the girdle provides support to the center of the caps as well, which the MVP one does not. Great input! thanks! I will go for billet main caps, upgrade the rod bolts and the cp wrist clips. I have not heard anything that this is necessary to upgrade the clips but I will do it according to your input and it is just a small change. just a little bit strange that the BC not can give me a proper spec that me rods can handle with 625 arp bolts! Edited January 6, 2014 by teddan (see edit history) Quote Link to comment Share on other sites More sharing options...
V8KILR Posted January 6, 2014 Share Posted January 6, 2014 Great input! thanks! I will go for billet main caps, upgrade the rod bolts and the cp wrist clips. I have not heard anything that this is necessary to upgrade the clips but I will do it according to your input and it is just a small change. Here is why I'm upgrading my std CP wrist pins. http://www.supraforums.com/forum/showthread.php?707377-WARNING!-10-1-CP-Pistons-come-with-weak-wrist-pins just a little bit strange that the BC not can give me a proper spec that me rods can handle with 625 arp bolts! Using a quote from Top Gear, "It's like asking a submarine captain how deep his submarine can go. Until he actually takes it to the point the hull crushes, he doesn't know." Personally, I think the stock crank will fail long before the BC rods give way. Quote Link to comment Share on other sites More sharing options...
teddan Posted January 6, 2014 Author Share Posted January 6, 2014 Here is why I'm upgrading my std CP wrist pins. http://www.supraforums.com/forum/showthread.php?707377-WARNING!-10-1-CP-Pistons-come-with-weak-wrist-pins ooops. Good to know! I will order the ones you wrote. Thanks! Using a quote from Top Gear, "It's like asking a submarine captain how deep his submarine can go. Until he actually takes it to the point the hull crushes, he doesn't know." Personally, I think the stock crank will fail long before the BC rods give way. Hahaha but if the submarine are spec 180 meters depth by the manufacturer. But the say "please only try 130m", Then it is something fishy Quote Link to comment Share on other sites More sharing options...
V8KILR Posted January 9, 2014 Share Posted January 9, 2014 (edited) Here's the part number for the pins: 866225025C3C PRO PIN:866x2.250x250/22mm Edited January 9, 2014 by V8KILR (see edit history) Quote Link to comment Share on other sites More sharing options...
teddan Posted January 10, 2014 Author Share Posted January 10, 2014 Thanks! Quote Link to comment Share on other sites More sharing options...
