Iky Posted January 3, 2014 Share Posted January 3, 2014 Hi, I'm planning on powder coating the whole intake I've got the throttle body removed but just want to double check, how easy will it be to re-calibrate the throttle position sensor when re-fitting? Also I think there is another position sensor for the traction control I think? If someone could please confirm. Quote Link to comment Share on other sites More sharing options...
David P Posted January 3, 2014 Share Posted January 3, 2014 The sensors are easy enough to position, details in WSM. Reassembling the butterflies, ramps, springs and stops correctly will be the challenge. Quote Link to comment Share on other sites More sharing options...
Iky Posted January 4, 2014 Author Share Posted January 4, 2014 The sensors are easy enough to position, details in WSM. Reassembling the butterflies, ramps, springs and stops correctly will be the challenge. Cheers David, I do like a challenge! (not) wsm on the home page isn't working for me at the moment. Quote Link to comment Share on other sites More sharing options...
David P Posted January 4, 2014 Share Posted January 4, 2014 (edited) Throttle body strip and reassembly is an art, get yourself an un-tinkered with spare for reference, or you'll stumble. Can be very dangerous if you get it even slightly wrong. Try the WSM with another browser, or better still get a hard copy. Edited January 4, 2014 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Iky Posted January 4, 2014 Author Share Posted January 4, 2014 Throttle body strip and reassembly is an art, get yourself an un-tinkered with spare for reference, or you'll stumble. Can be very dangerous if you get it even slightly wrong. Try the WSM with another browser, or better still get a hard copy. It's ok now David, got it working in chrome. Quote Link to comment Share on other sites More sharing options...
Andrew K Posted January 4, 2014 Share Posted January 4, 2014 Use a camera and take loads of pics as you disassemble it so you can look back and see how it goes together, that's what I did and used the Toyota workshop manuals I have. Quote Link to comment Share on other sites More sharing options...
Iky Posted January 4, 2014 Author Share Posted January 4, 2014 Cheers, decided to engrave small match marks across. Quote Link to comment Share on other sites More sharing options...
