FOSTA Posted January 1, 2014 Share Posted January 1, 2014 Hi guys, Just need abit of advice. Im currantly rebuilding my engine at the moment 2jzge (na-t) and I wanted to replace every seal and bearing, nut and bolt! Now looking at my crank and block itself looks fantastic! There wasn't much carbon build up at all and the bores look perfect! ( no score marks etc.) Now I've just orderd a full set of clevite 77 bearings for the bottom end in standard sizing from Titan Motorsport. Now reading a post by dazzi on team na-t, he says that his did not fit! They where too lose on some jernals and too tight on others! He then says that he had to order his bearings from Toyota in different sizes to match the crank and the same for the conrods! Is this always the case or have any of you guys fitted one size bearings throughout and it's been fine? Thanks for any advice guys Link to comment Share on other sites More sharing options...
V8KILR Posted January 2, 2014 Share Posted January 2, 2014 The ACL main bearings that I used were all the same size. Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 2, 2014 Share Posted January 2, 2014 Plastigauge is your friend, if you don't have access to bore gauges and micrometers. Link to comment Share on other sites More sharing options...
Swampy442 Posted January 2, 2014 Share Posted January 2, 2014 I think the bearing sizes are stamped on all the main caps and rod ends? There will be a number that corresponds to a bearing size/Toyota part number. Example :- 11711 BEARING, CRANKSHAFT 11071-46010-01 MARK 1, NO.1 1 $22.25 11071-46010-02 MARK 2, NO.1 1 $22.25 11071-46010-03 MARK 3, NO.1 1 $22.25 11071-46010-04 MARK 4, NO.1 1 $22.25 11071-46010-05 MARK 5, NO.1 1 $22.25 11701-46010-01 MARK 1, NO.2 6 $20.82 11701-46010-02 MARK 2, NO.2 6 $20.82 11701-46010-03 MARK 3, NO.2 6 $20.82 11701-46010-04 MARK 4, NO.2 6 $20.82 11701-46010-05 MARK 5, NO.2 6 $20.82 Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 2, 2014 Share Posted January 2, 2014 The crank size stamping is irrelevant on a used crank, we are talking tenths of a thou inch. The crush figure on the block is also irrelevant on none OE shells. You can either learn to use a bore gauge and micrometer properly, (not as easy as it looks), or use Plastiguage. Link to comment Share on other sites More sharing options...
absz Posted January 2, 2014 Share Posted January 2, 2014 I used clevite 77 bearings on mine using plastigauge to check the clearence and had no issues. have you any wear marks on the old bearing shells? Link to comment Share on other sites More sharing options...
FOSTA Posted January 2, 2014 Author Share Posted January 2, 2014 I used clevite 77 bearings on mine using plastigauge to check the clearence and had no issues. have you any wear marks on the old bearing shells? No mate, everything looks sweet and smooth. Link to comment Share on other sites More sharing options...
FOSTA Posted January 2, 2014 Author Share Posted January 2, 2014 The crank size stamping is irrelevant on a used crank, we are talking tenths of a thou inch. The crush figure on the block is also irrelevant on none OE shells. You can either learn to use a bore gauge and micrometer properly, (not as easy as it looks), or use Plastiguage. Thanks for that Chris I'll order some plastigauge and take measurements. Could you tell me what tolatance/ spec I need to be in when I take these mersurments? Thanks Link to comment Share on other sites More sharing options...
hodge Posted January 2, 2014 Share Posted January 2, 2014 All tollorence's are in the works manuals. There's a works manual app for iPhone. Link to comment Share on other sites More sharing options...
fastby4 Posted January 3, 2014 Share Posted January 3, 2014 ACL and Clevite STD bearings have the same thickness (1,495mm) as the OEM bearings with this no. 11071-46010-01 (1,495mm) Thomas Link to comment Share on other sites More sharing options...
fastby4 Posted January 3, 2014 Share Posted January 3, 2014 the 1,495mm is for the rod bearing and for mains is it 1,995mm thickness Link to comment Share on other sites More sharing options...
FOSTA Posted January 3, 2014 Author Share Posted January 3, 2014 ACL and Clevite STD bearings have the same thickness (1,495mm) as the OEM bearings with this no. 11071-46010-01 (1,495mm) Thomas Thanks for that mate Link to comment Share on other sites More sharing options...
Stevo Posted January 3, 2014 Share Posted January 3, 2014 All tollorence's are in the works manuals. There's a works manual app for iPhone. I'm assuming mine were all within tolerance mate? Fosta, where they loads cheaper at Titan like? I just got mine from here for £150 posted http://streetracersgd.co.uk/index.php/shop/category/329-engine-bearings-supra Link to comment Share on other sites More sharing options...
Slutters Posted January 4, 2014 Share Posted January 4, 2014 Plastigauge is your friend, if you don't have access to bore gauges and micrometers. This, i did both on my engine and found the Plastiguage accurate. Make sure you use a good assembly lube like Redline. Link to comment Share on other sites More sharing options...
Slutters Posted January 4, 2014 Share Posted January 4, 2014 Found some pics, full build thread: http://www.mkivsupra.net/vbb/showthread.php?295119-Slutter-s-800HP-Forged-Motor-Build!-%28Update-Page-4!-6-10-13%29 Plasti-gauge strips in to check oil clearnces: Redline assembly lube and ARP Molly grease Link to comment Share on other sites More sharing options...
hodge Posted January 5, 2014 Share Posted January 5, 2014 Double post Link to comment Share on other sites More sharing options...
hodge Posted January 5, 2014 Share Posted January 5, 2014 I'm assuming mine were all within tolerance mate? Of course Link to comment Share on other sites More sharing options...
FOSTA Posted January 5, 2014 Author Share Posted January 5, 2014 I'm assuming mine were all within tolerance mate? Fosta, where they loads cheaper at Titan like? I just got mine from here for £150 posted http://streetracersgd.co.uk/index.php/shop/category/329-engine-bearings-supra Wey not loads cheaper £90 posted from titan but I only got mine from there because I was alrady waiting on a order from them so it made sense really. Link to comment Share on other sites More sharing options...
FOSTA Posted January 5, 2014 Author Share Posted January 5, 2014 Found some pics, full build thread: http://www.mkivsupra.net/vbb/showthread.php?295119-Slutter-s-800HP-Forged-Motor-Build!-%28Update-Page-4!-6-10-13%29 Plasti-gauge strips in to check oil clearnces: http://i158.photobucket.com/albums/t83/adamrutland06/P1040624_zpsd76c72d8.jpg Redline assembly lube and ARP Molly grease http://i158.photobucket.com/albums/t83/adamrutland06/P1040625_zps90cd09ee.jpg Cheers mate, yeah I have engine assembly lube mate Link to comment Share on other sites More sharing options...
