ABS ecu question
LOGIE
Find the plug in connector inside the plastic on the engine bay / wheel arch divider just in front of where the ABS wire clip bolts on. Separate the connector. using your multi meter (you DO have a multi meter, if not GET one...NOW.....less than £10) check the resistance of the sensor and lead. One is probably open circuit. Do the same with the rear`ones. The system will flash fault codes if you bridge the right diagnostic terminals, and tell you which sensor or whatever is not sending a speed signal. See`workshop manual.
