LOGIE Posted December 28, 2013 Share Posted December 28, 2013 (edited) Ok so correct me if im wrong but should the stock electric fans just switch on when the coolant temp gets to a certain temp? My electric fans are on straight away from start up. I should say im NA-TT but I changed the engine bay loom so I could have the benefits of additional cooling and the fan relays are present. I do have the coolant temp switch in the radiator Edited December 28, 2013 by LOGIE (see edit history) Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted December 28, 2013 Share Posted December 28, 2013 (edited) Ok so correct me if im wrong but should the stock electric fans just switch on when the coolant temp gets to a certain temp? My electric fans are on straight away from start up. I should say im NA-TT but I changed the engine bay loom so I could have the benefits of additional cooling and the fan relays are present. Take it you didn't get that sensor for the bottom of the rad yet then? Edited December 28, 2013 by TheTurtleshead (see edit history) Quote Link to comment Share on other sites More sharing options...
LOGIE Posted December 28, 2013 Author Share Posted December 28, 2013 Take it you didn't get that sensor for the bottom of the rad yet then? Sorry mate I updated the op at the same time you posted, yeah I got a temp switch Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted December 28, 2013 Share Posted December 28, 2013 Sorry mate I updated the op at the same time you posted, yeah I got a temp switch Drat! You have stolen my daily opportunity to be a smug bastard. Hmmm. Stuck/dodgy relay? Quote Link to comment Share on other sites More sharing options...
LOGIE Posted December 28, 2013 Author Share Posted December 28, 2013 Drat! You have stolen my daily opportunity to be a smug bastard. Hmmm. Stuck/dodgy relay?possibly, got a spare? Quote Link to comment Share on other sites More sharing options...
ScottC Posted December 29, 2013 Share Posted December 29, 2013 (edited) You don't have the air con pressure switch plugged in Edited December 29, 2013 by ScottC (see edit history) Quote Link to comment Share on other sites More sharing options...
LOGIE Posted December 29, 2013 Author Share Posted December 29, 2013 You don't have the air con pressure switch plugged in Aahhhhh that true. I couldn't find a deep enough 27 mm socket. I didn't realise that would cause the fans to run. How did you know mate? Were you at my car overnight? Quote Link to comment Share on other sites More sharing options...
ScottC Posted December 29, 2013 Share Posted December 29, 2013 (edited) I just linked out the two extra wires on the TT plug until I had it fitted. Aahhhhh that true. I couldn't find a deep enough 27 mm socket. I didn't realise that would cause the fans to run. How did you know mate? Were you at my car overnight? I had the same problem until I looked at the wiring diagram and realised they were wired in series. Edited December 29, 2013 by ScottC (see edit history) Quote Link to comment Share on other sites More sharing options...
Fizzy T Posted December 29, 2013 Share Posted December 29, 2013 Does the TT not have these then or are you talking about the twin small fans that are used to cool the condenser? I removed those thinking they were just for the A/C. Quote Link to comment Share on other sites More sharing options...
LOGIE Posted December 29, 2013 Author Share Posted December 29, 2013 I have twin fans built into the rad shroud. Not removable Quote Link to comment Share on other sites More sharing options...
Fizzy T Posted December 29, 2013 Share Posted December 29, 2013 Mine were built to fit to the fan shroud but were removable. Quote Link to comment Share on other sites More sharing options...
LOGIE Posted December 29, 2013 Author Share Posted December 29, 2013 Mine were built to fit to the fan shroud but were removable. I know the one you mean mate its a Y shaped bracket with 1 fan that comes off. Mine is a facelift shroud that has 2 built in fans. Quote Link to comment Share on other sites More sharing options...
